Frozen Router Collet and Red Face
>Good Afternoon Friends,
I had to do a swap out of 1/2" bits in one of my P+C 690 routers. I removed the router from the table and removed the router insert base from the motor, set the motor on its flat top and engaged the two flat stamped wrenches on the collet hex nut and squeezed. Squeezed harder. Squeezed very hard. The nut wouldn't budge. The bit remained anchored in place. I repeated the process. Normally the nut turns with some effort and releases the shank easily. I figured I'd get mad enough to intimidate the router into giving me back my bit, and gave it some explicit verbal direction. SWMBO happened to be in the laundry and came in the shop to see what the ruckus was all about, and looked at the problem. She asked if both wrenches were supposed to be on a single hex nut. Does two wrenches on the same nut make it twice as easy to turn? Does the nut turn clockwise and counterclockwise at the same time? Is a wrench supposed to go on the other nut? I've been using that router for almost 10 years and never made that kind of a dumb mistake. Its a good thing only I make those kinds of mistakes.
George
