OT OK Computer guys, I need more help
>On 8/15 my accountant sent me a bunch of questions as an attachment to an email. They were a DOC file and I opened them. It launched WORD and I answered the question and saved them.
In the mean time I have run Ad Aware, spybot and Ccleaner, trying to speed things up.
Now I cannot find the Document I saved. When I went back and opened it again and tried to save it, the little blue bar at the top flashed on and off and the button on the tool bar at the bottom of the screen flashed along with it in unison. I waited a while and Did Ctr/alt/dlt and it said it was running. So I closed that screen and at that point Word asked if I wanted to save the changes, I had made no changes so I said NO. I tried it again and the same thing happened.
Also, when I opened Word, there was no list of recent work under OPEN, I am thinking all the clean up treated that as Cookies and dumped the list.
I have used Search to hunt for the documents, but no luck.
The sender used AOL and I received it in Outlook Express through Comcast. Can anybody tell me where Word/Outlook would have stored the document I worked on? Is there a chance the saved file with the answers to the questions is in there somewhere?
Re: OT OK Computer guys, I need more help
ebd
ebd
>This will usually work with any program to find out where it's saving files. Get in to the program (in this case Word). Click on F)ile, S)ave and look at the folder that the program wants to use for the save (it will be at the top of the pop-up window and labeled "Save in"). Almost all programs use one of two methods to determine the folder. 1) The last folder saved to: and 2) A "hard coded" default folder that it tries to use every time. For both Word and Outlook Express the folder is usually "My Documents".
One other thing to consider. The file may have taken a default name if you didn't give it a specific name. If you do a search on all files with a .doc extension (search argument *.doc) you will have a long list to look through but you will definitely be able to find it as long as it's there.
One last thing to try. Open the Recycle Bin and make sure that it's not there.
David Yoho
>Attached files in OE are saved in temporary folders. Unless when you opened the file you saved it to a new location, it is probably still located in the temp folder. One thought to be able to access the original file again, even if you saved an amended version to a new location, would be to go back in OE and find the email with the attachment. Click on the attached file and see if it doesn't open again. If so, be sure when you make your changes this time that you save the file to a known location on your hard drive.
David
JKJ in East TN
To find it easier after such a search, click on the Modified field in Explorer to sort the files by the last date modified. This should put the most recent file on the top bottom, or click again to put it at the top of the list. (If the Modified field is not present in Explorer, right click on the field header (i.e., on the heading Name, In-Folder, etc) and click on Modified to enable it.)
But what I usually do when I've accidentally saved a file in the wrong place is make some new document and see where Word want's to save it, then look there for the file. Note that if there was any sort of problem with Word itself when the file was saved, it may not have the name you expect.
ebd
ebd
>Not when you do a S)ave as. At least not in my installations. All the computers on the network save to My Documents from OE. I just checked.
