Re: Gasoline/Chainsaw question (OT?)
Rob Stokes in North Vancouver
>Larry's answer is the best one. 2-stroke engines typically don't need anything above 87 octane. Consumer equipment is built to run on readily available fuel, and that's what's readily available. Depending on the 2-stroke, you can actually damage an engine by running a higher octane (this is mostly attributed to marine engines though).
Use 87 Octane - it's all you need.
More important is your choice of mixing oil. Don't cheap out on it - get decent brand name 2-stroke oil and mix it to the manufactures specs. Don't get marine oil though (TC-W3) - it's designed to support a higher compression 2-stroke that typically runs cooler than air cooled engines at sustained high RPM's. Most oils these days support 50:1 as they have better lubricity than the oils of old. Older oils demanded 32:1, or sometimes ratios that were higher. Not any more. And contrary to popular opinion - more oil is not better. Upping the ratio of oil/gas arbitrarily can cause an oil film to build on the steel components inside the engine. This in turn can reduce heat transfer which can end up causing more damage. If your saw's designed to run at 50:1 - run it at 50:1. If you've got your own tar field on your muffler - check your math when you mix.
Larry's concept of adding an aftermarket fuel stabilizer to the gas cans he uses to support his small engines is by far the best practice. Make it a habit and it will become one. Once done, you never have to worry about "bad gas" again. I also do this with my boat gas - it's FAR cheaper in the long run.
The advice you got on not using plastic tanks is bunk. The polymers won't degrade. Think about it - if that happened, eventually the tanks would start to leak from the inside out. I've never seen that happen. And if the plastic tanks did act as you've been told, there's no way the material would be approved for use by the USCG in marine fuel tanks - which it is. So feel free to use plastic tanks - it makes no difference. In fact - I prefer plastic tanks. Water in the fuel is a fact of life - maybe you got it form the gas station - maybe you left the lid off the gerry can when it was raining out. Regardless, water happens. I'd rather have a tank that's impervious to water than a tank that will rust. You won't find a steel tank at my place, and I've got tanks for boats and lawn mowers and chainsaws and and and....
Oh - it's a good idea to use a filter, but chainsaw carbs do not "clog up easily". In fact, they're quite forgiving and the tolerances on a small carb like that are WAY bigger than a carb used on a car. Car's have their fuel economy measured by governing bodies so there's incentive to make a fine-tuned carburetor. Chain saws need to run when you need them and no one cares about their gas mileage. As such - they're designed for dependability, not efficiency. Dependability in a chainsaw means letting the odd piece of sawdust pass without incident.
Hope that helps.
Rob
