Purpleheart
Purpleheart
Purpleheart
Bob in NE Ohio
>I have built both of my grand daughters a rocking horse for their first christmas and now it is time for a third. Both have been made from hard maple for the bodies and legs with the saddle, mane, tail, forelock and rockers from dark walnut.
I do not want this one to look like her sister's so I was thinking of using purpleheart as a substitute for the walnut. My concern is using purpleheart for the rockers. Does anyone know of a reason it would not be strong enough to hold up to the stress on the rockers? They would be made of a glue up of two 3/4" layers with offset joints. The arched rockers are about 42" long.
Thanks for the help
Bob
Re: Purpleheart
Re: Purpleheart
DizD
>From my limited experience, strenght won't be a problem. It is splintery while working like a lot of the dense tropical hardwoods. If all edges are rounded it should polish up like a gemstone.
Re: Purpleheart
Re: Only the color...
>In my only experience with purpleheart, the nice purple color faded away and turned sort of light brown. There are supposedly some finishing tricks so this won't happen, but I didn't know them.
Re: Purpleheart
Re: Purpleheart
Ronald Walls, Ohio
>i built a shelf with purpleheart and i thought it was just as hard if not harder than walnut. i have used walnut to. and as far as fading later, that has not happen yet and it is about 5 years old.
Re: Purpleheart
Hard stuff!
>I've used purpleheart. It has a Jankara hardness of 1860 which is almost the same as Hickory. It is very hard!
It will hold up, plus termites won't eat it - at least for a long time!
Re: Purpleheart
Re: Purpleheart
Mark Kauder, Phenix City, AL
>Let's put it this way, in South America is a construction grade wood used in the construction of RailRoad bridges and the like. HARD and Strong.
Mark
Re: Purpleheart
Re: Purpleheart
Frank Orfanello
>As others have said it will be plenty strong! I have used it for several projects but have not yet found a way to keep its color. It fades to a brown color fairly quickly in my experience. YMMV
Re: Purpleheart
Re: Purpleheart
Steve Schoene
>If you want it to stay purple longer, dye it purple at the beginning.
