Subdomain question
Lee Grindinger
>Does a subdomain behave the same to all viewers as a regular domain? Will a subdomain appear whether you type www.subdomain.com, or subdomain.com
Are there any differences to the viewer at all?
Thanks you guys, Lee
Subdomain question
Lee Grindinger
Re: Subdomain question
Dave MacLuskie in Virginia
>My (quite possibly flawed) understanding of the subdomain was that it was part of the primary domain. So.. macluskie.com is my domain name. dave.macluskie.com would be the "dave" subdomain of macluskie.com, so yes, you'd have to type in the front part.
Someone please correct me if I'm off kilter!
One possible hitch
>Subdomains, as Dave points out, are part of your main domain but browsers may see links to them as links out of your main domain, and you could have problems with pop-up blockers or firewalls trying to prevent such links. Our sightings window is in a separate subdomain (sightings.woodcentral.com) so that I can restrict ftp access only to the subdomain.
Sort of
>It all depends on how it's defined in the DNS server and also a little bit to do with how the web server treats the host header.
Often, the root MYDOMAIN.com is set to point to the same IP address as the WWW.MYDOMAIN.com, but it doesn't have to be (and may not be) set that way.
Then the way the target server treats the request... well that can complicate things. Everything's virtually virtual ;)
I could go on (and on and on) but you'll start throwing rocks demanding that I stop ;)
Happy Woodworking!
Jim in N. Va.
>I am not an expert and so can only answer from my practical experience. You asked whether a viewer could type subdomain.com or www.subdomain.com and get to the same place. In my experience, the answer is yes. I have a web site www.indianlakevacation.com that I use to advertise my vacation rental home. It is actually a subdomain of something else. However, it appears and behaves just like any web site--at least with how I and potential guests use it.
