Re: Grr-Ripper Questions
Larry Clinton At Frankfort (Central)., Indiana
>I have looked at the Grr-Rippers once or twice. I have to admit, the $50 price stopped me, and they looked pretty complicated.
My question is, do they require a lot of fiddling and set up?
Barry, I use my Rippers every time I rip a board on my Unisaw, sometimes on the router table and jointer. The Grr-Rippers are pretty easy & quick to set up. with boards 2" or more wide - normally you just orientate the ripper so the blade passes between the rails. (end for end orientation). Once in a while you have to adjust a rail by sliding it in the ripper. This is a 5 to 10 sec. operation (each). The only other issue is that you have to watch the blade height so you don't cut into the "bridge" of the Grr-Rippers. This you can't cut 1/4 thick and 2" thick with the same blade height. The demo tape or Cd (can't remember which I have) does make it look like you have to set up for just about every width. I guess you could, to have the Gripper rails right on each side of the saw blade. Does make it slightly safer as the off-cut is controlled clear through the cut and past the blade. But to be honest, I really don't do that. Basically the adjustments are to keep from cutting a slot in the rails. You check by running the ripper against the fence and past the blade (saw OFF) to see if the blade hits a rail. If it does, flip the ripper end for end and try it again. If it still hits, you have to slide a rail over or add a "side" rail to align the slots between the shoes with the blade. (Ain't rocket science) if you goof, it won't hurt the blade, but smells funny (melted plastic) and you now have an extra slot in a shoe. (I have a few - do need to get some new bottom rails).
Do you change them around for various jobs? Often? Or do you just pick them up and use them?
As above, you may have to slide or add a rail for various widths. Narrower pieces require the addition of the "shoe" to keep the ripper level and allow more control. This takes 30 sec to a min each to add and adjust. However you will find the time is saved many times over with the accuracy you get having the proper control. I can rip any length 1/4" to 4" wide strips safely and very accurately (guessing +/- .002" wide). By the way all the adjusting & attaching screws are fitted with knurled knobs, and are captive in the parts except the screws that hold the handle in position - I haven't moved the handle more than 2 - 3 times in 3 years, so tools aren't required for adjustment.
Looks like I will be buying or making more push sticks. I got a warning. I am in the habit of clamping my hand to the fence and using my thumb and forefinger to slide the work through. I changed the fence and that might have changed the angles or maybe it was just time for a warning, but last night I kicked my thumb. I was very lucky (yes and Stupid). It was less than a paper cut and at first I did not think it would bleed, but it was a cut. Perfectly in one of the little creases on the back of my thumb. Time for some push blocks and sticks and time to use them.
I highly recommend the Grr-Rippers. I have damaged mine over the last 3 (or more) years use thorough careless use or setup. I need to replace a few of the lower rails on my set of 2 of the (Deluxe) units. However if they were damaged beyond repair I would consider it money well spent and would buy a couple more.
