ADVERTISE HERE - FREE TRIAL
OT computer building
joe grittani
>A young friend just finished building a monster pc for gaming purposes and is thus far unable to install Windows Vista. I figure there must be at least one website like this one for computer folks but don't have a clue what or there they are. Any ideas would be appreciated. I'm no help because I'm convinced we're not speaking the same language.
TIA.
Joe Grittani of Dayton, OH, curently in Coos Bay, OR
Re: OT computer building
Computing.net
Ray Thompson - Middletown,IN
>Haven't been there for a while but they used to have some good info. 'Course there are some good IT guys here that can probably help.
Ray
Chuck W
>If your friend cannot load Vista then there are several possibilities. The motherboard has a BIOS and maybe the optical reader is not set to be a boot drive. A little more information would be helpful.
Suggestion
>IF he can, try loading WindowsXP on it first, that will tell if the problem lies with Vista compatibily (Very likely) or just hardware problems (also possible).
These days building PC's is good for education purposes only. You can learn alot building our own PC (just like this, thought trial and error) but you dont' same much money building them yourself these days.
Geeze, guess it's just like woodworking, eh?
Happy Woodworking!
building a computer
JKJ in East TN
>>...You can learn alot building our own PC
I still chuckle when I hear about people "building" a computer. The reason is some time back (mid/late '70s), building a computer involved digital circuit board design, soldering, and writing software from scratch! My first was a SWTPC 6800 with 2K (not meg) of memory. I later added several 8K memory board kits at $250 each - assembling the kit required 1434 solder connections (I counted them). That machine ended up maxed out with 56K RAM, a fast 2MHz processor (not GHz), a bubble memory drive, dual 8" floppy disk drives ($2400!), a home-build CRT terminal, a teletype for printing and paper tape reading, and several custom boards made from scratch including my pride and joy, a 512x512 B&W graphics board.
But the statement above was certainly true then as now - it would have been difficult to build such a machine and make it work without learning something.
Re: building a computer
Jerry Nicholson
>My first was a little more primitive - Intel 4040 with 256 bytes of RAM. I had to solder all the components to the circuit board. Programmed with slide switches & LEDs directly on the circuit board. The second was all hand soldered too - 6502 processor, interfaced to an extensively modified TV, hand wired keyboard, initially 512 bytes of RAM later upped to 12 kilobytes of RAM and 8 kilobytes of EPROM (all those 1k x 1 memory chips hand soldered too). I still build my own computers but that is a lot like snapping together a few Leggo blocks now.
Jerry
Joe Grittani
>Thank you all for your input. He managed to sort things out and everything is working great.
Again, thanks. This place is truly amazing.
Dan Donaldson
>Remember the Altair and imsai? The first machine I put together was an imsai. Mimeographed instructions (cut this track and solder a jumper here and .....) Install the bootloader through the front panel switches etc. I remember that the big topic of the day was hex or octal, with rabid fans in both camps. The switches on the front panel were colored and you could arrange them to represent either hex or octal. Fun times.
This was around 1976 or so. Funny how time flies when you are having fun ;-)
Norman (Ottawa, Ont.)
>Dan..
I have a running Imsai 8080 here I put together in 1979-1980.
I did my university studies in the early to mid-80's and used it extensively. It has upgraded dual Z-80's and double-density, double-sided 8 in. floppy drives and runs CP/M V2.2, Turbo Pascal, Mix C Compiler, etc.
I almost chucked it a couple of times during moves, but am very glad
I hung on to it, apparently it's worth a few bucks today.
Hard to believe the thing still works, but it does :)
Those were the days, I remember poring over it with a oscilloscope for weeks on end trying to get it to work with all the mix and match S-100 cards in it.
Norman
Dave Arbuckle, Plano, TX
>Unlike Norman's, mine doesn't still work, but this machine occupies a place of honor in my home office. :-)
