Re: My choice - MM-16
Larry Clinton At Frankfort (Central)., Indiana
>I have the MM 16. I went through the same kind of deliberations you are going through now. I went to the tool show at Indy, looked at the saw's there - Delta 20" (very weak trunnion - easy to wobble table), Jet (ok saw, less capacity, not MM quality), Laguna (not impressed with the ridigity - high priced, less capacity, small motor, from reports, customer support poor), Grizzly ( decent saw -similar to Jet ). Steel City, (nothing in the 16" resaw range otherwise decent saw), Powematic (priced fairly high - had to look at 20" to approach re-saw capacity of MM 16 otherwise nice saw). I researched the web sites, looked at everyone's opinions. After narrowing it down to the MM16 or Laguna, I did more research. The Laguna, doesn't have the capacity of the MiniMax until you get into a bigger saw - and dollars. Also I found a lot of discussion about the lack of customer support for the Laguna. As a retired manufacturing / quality engineer, I had looked at the construction of the MM-16 and was quite impressed. The trunnion is excellent, table is flat, motor is more powerful than any I have seen on the market in a saw this size (4.8 hp.), full 16" re-saw capacity, the adjustments are easy to get at and use, euro style guides which are a breeze to adjust. mobile base is included, frame is extremely well designed etc. The MM-16 is on sale right now for $2295 + shipping. The sale's rep has called me and emailed me several times after I purchased the machine to see if I had any problems - I haven't but it is sure nice to see they don't forget their customers after the sale. I purchased a couple of the Woodslicer blades from Highland hardware (1/2 & 3/4). I have re-sawn white oak - about 8-10" - saw doesn't even sound like I loaded it. tracking is excellent. The only thing I didn't like is the On / Off switch design, although it has worked fine, I just don't like the design. It would be easy to change if I desire - after the warranty is expired. I have no affiliation with Mini Max, just a very satisfied customer. By the way the MM16 will run 1/4" blades so may want to eliminate the Delta for space.
