oily woods and drum sanders
Tom Sontag - St. Louis
>My Performax 10-20 is no powerhouse tool, but it does what I need and fits my shop and work. I've gotten used to lowering the drum in very small increments (often less than 1/8 turn which is 1/128" I think), but it still loads the paper when sanding African blackwood or cocobolo. It can be arduous to remove the stuck bits and seems silly to waste a fresh roll after two passes. I tried lightly setting the crepe block paper cleaner on the drum as it sands and that seemed to help some (too hard generates rubber bits all over), but maybe someone out in WoodCentral land can offer a more encouraging approach?
I am running the feed at about 50-70%; maybe speeding it up on very light passes would keep things from heating up? Does gumming up sandpaper correlate with heat? Any ideas welcome!
Re: oily woods and drum sanders
>Tom, I just made a Headboard of heart pine. It was a nightmare for the Performax. A piece over about 2' was about all that would go through. After that it was so gummed up I had to change the belt. On wide stock it was "one pass" New belt". I have a 16/32 and the belts are $7 or 8. Too much to throw out after a minute of use. So I feel your pain.
I clean the belts in a Solution of Simple Green. (about 1/3 SG and 2/3 water or stronger) I have it in a plastic gallon jug deep enough to submerge the belts and several will fit in there. I just put them in and let them sit. Several hours may be enough for lightly gummed ones but over night was necessary for some. Some required repeated baths. Then I stand at the kitchen sink and scrub them with a tooth brush or other nylon brush and in stubborn cases a soft brass vegetable brush. And I flood them with water and then hag thumbs up to dry. Sounds worse than it is. Only takes about ten minutes of work plus soaking time. I got a stunning amount of wood dough off mine.
I can clean a bunch of belts on one batch of Simple Green.
Vinegar helps on embedded glue and oven cleaner will work on really tough stuff, but I have not tried it yet. (be careful, nasty stuff)
And you are correct, use very light passes and keep the stock moving as fast as you can. I usually run mine at 100% and rather than slowing down take even lighter passes. I think the speed and light touch reduces the heat. You are cooking and burning the sugars and starches in the wood and caramelize and become sticky.
PS, I have left some belts in the solution for weeks (I forgot) and it did not seem to hurt them.
Paul Woolson
>Tom, there's a thread down a little lower that addresses this a bit too.
But alas, cocobolo will kick your fanny every time with a drum sander. But here are some tips:
VERY,VERY light cuts with coarse paper (80 grit min)
100% feed rate
Try running the stock as close to cross-grained as possible. The resin tends to "pool" between grain lines and when heated up it just keeps picking up more, if it is run straight through the sander. If you run it close to cross grained, the problems will be less.
I've got a bucket of pitch remover, for saw blades, that I occasionally soak them in. It helps but once you get a fleck of resin, it will just start burning. So you have to get it ALL off.
Good luck. Paul
Mike Fitterling
>I am not a handtools only do or die kind of guy, but it strikes me that this machine is really not the tool for the job. Why go to all that expense and work to clean up the belts when a scraper could do that work with much less trouble? Sounds like the manual and messy labor of cleaning those belts up far surpasses the work required by a cabinet scraper.
because....
>I use it primarily on very thin stock. I only got the drum sander to make 1/4" thick or less pieces.
And...
Paul Woolson
>...it's accurate. I'd be pretty hard pressed to thickness a board (8" x 22") to .090" and keep it within .002" along the length with a scraper.
Tom, I forgot to mention one other little trick. Unless you have a "show" face that you don't want to take material from, try flipping it over each pass. One pass from the top, one from the back, etc.
Hmmmm, Cocobolo? Sides thinned beyond 1/4"? You aren't making guitars are you?
not guitars
>I find myself making smaller and smaller items; boxes mostly. Luthier grade boxes, that's it.
And you were right about thicknessing. I use my drum sander as an accurate thicknesser of thin material. It never comes out ready for finish.
Rob Sandow
>I have had a 22-44 Pro for about 5 years. I actually don't find much of a problem with loading from very oily woods if I take light passes and use a rubber cleaning stick often. I don't recommend using it for softwoods though. I ran some reclaimed old growth SWP through it a few years ago and the pitch immediately gummed up the paper and hardened so it was impossible to remove.
Rob
