Waterlox question
Waterlox question
Waterlox question
wilbur
>I'm using Waterlox for the first time --Waterlox Original Sealer & Finish (the red labeled one). It's for a worktable top that I want to make water resistant (I don't need waterproof).
For those of you who have used this stuff before, how many coats to you typically use, and do you brush or wipe on?
Re: Waterlox question
Greg Haugen
>Depending on your table's wood. The first coat or two I'd brush it on and let it soak in, wipe off the excess. This thicker coat(s) will take longer for it to dry. Give it time, at least over night if not more. After that I'd wipe it on with a rag to build up the "protection." The key is leave the finish IN the wood not on it. Eventually you build it up so it will be on it. But wipe off any and all "free standing" excess when applying coats. I'd say a minimum of 3 coats for a workbench, possibly up to 6. Some may say that's excessive. A workbench will be used and abused. It couldn't hurt.
just my 2 cents.
Greg H.
Don't wipe off the excess
>Waterlox is a varnish, and the object of a varnish is to build a protective film on the wood. Sometimes it is confused with a Danish oil finish, which is intended to reside mostly in the wood. Film finishes offer more protection from moisture and abrasion, but if you really want abrasion resistance, I'd suggest a harder varnish such as a polyurethane.
Sorry, my bad. Do what Ellis said. :-))
Greg Haugen
Terry Quiram
>Wilbur
I use Waterlox as a finish for my turned bowls. I wipe on and use a minimum of 3 coats. I lightly scuff with 4/0 steel wool between coats and always use a tack rag before the next coat. If you are not going to use most or all of the can I would recommend decanting into smaller containers. It doesn't age well.
Terry
