ADVERTISE HERE - FREE TRIAL
25" Performax drum sander burning?!
Steve Silca
>I'm sanding some re-sawn mahogany slices about 12" wide on my new Performax. All of the sudden, the board comes out with 3 burn stripes. They are about 1/4" wide and an inch apart. The sandpaper itself is fine except in those few areas where it burned a stripe. This has not happened before - any ideas?
Re: 25" Performax drum sander burning?!
Thomas S Stockton
>Steve,
I have the Delta drum sander and there are a couple of causes.
1- too heavy a cut, this is the most common for me, you would think that more of the belt would burn but it is usually localized
2- not cleaning the belt enough when running pitchy wood. Pines the worst, glue lines that aren't scraped clean will do it also.
Seems like once they burn the belt needs to soaked in simple green and cleaned. If it is really bad even after cleaning the same spot will gum up and burn.
Another trick I use is to reverse the belts whenever I change them, this allows the backside(not sure if this is the right term) of the grit to wear out. This is easy to do when I change the belt I start rolling it up from the end that you install it from.
Tom
Paul Woolson
>What you've done is heated up the wood enough that resin has built up in those areas. Basically heated it to a melting point. Then once there is a slight dab of resin built up, it heats up the wood more in those areas, compounding the problem. Soon you have resin built up on the whole circumference of the drum.
What can you do about it now? Not too much. I've tried soaking the belts, picking it off with an exacto knife. And combinations of the two. Problem is if you don't get every little speck, you'll have the problem again very soon.
Bottom line, and I hate hearing this kind of stuff too, is that you need to take lighter cuts. Without knowing your particular machine I'm not sure how much of a crank your handle should move for a next pass. On mine it's 1/8" of a crank and that's the absolute max on non resinous woods. Put something through like Cocobolo and I can hardly even move the handle.
You can also put the wood through at an angle. Start it on the very left side and angle it as much as you can so that when the board is finished, it's on the very right side.
Increasing the grit will help. I'd recomend 80 grit. I use 60 on both drums of mine. The finer the grit, the more heat you are going to build up.
How's your dust collection? Evacuating the dust quickly will cool things down better.
Good luck. Paul
>You have gotten good advice. I clean my belts with Simple green and either a nylon brush or a soft brass (vegetable) brush. Then I flush them off with water and hang them up to dry. Also, clean them on the machine with one of the crepe rubber gummy sticks, frequently. If you get a really nasty belt, you can clean them with oven cleaner, but be careful with it. Also, vinegar works to some extent on glue that is stuck to the belt.
I also agree with the people that told you to take light cuts. I thought that since my Performax was labeled on the handle something about a 1/4 turn equals 1/64" that I should turn it a 1/4 turn. Not so. The coarser belts may be useful for removing stock, anything above about 80 really does not remove much, if any stock. At this point all you are trying to do is smooth the wood down to the level of the deepest scratches on the surface. Clearly you remove a little wood, but it should be a few thousandths of an inch. Each succesively finer grit just removes the scratches left by the previous one.
I find it works best to use very light cuts, use good dost pick up, and have the feed belt running as fast as you can. Keeping the wood moving helps reduce the heat build up.
Dennis Yoder
>Barry, I seem to get better finish by taking very light cuts as you do but I go very slow??? Dennis Y
Paul Woolson
>Going slow (feed rate) can give you a better finish because the belt hits each area more times. BUT...if you are using a wood that is prone to resin burning, you'll have more problems. Because of the drum hitting multiple times per unit of length, it's heating up more.
If I were to attempt to run the exotics, that I use for guitars, through at a slow feed rate, I'd have to change the belts after every pass.
ted Wong
>I had the same problem a number of years ago. As everyone else has said, very light cuts and very good dust collection is a must.
