Hey Mark Goodall
Hey Mark Goodall
Hey Mark Goodall
Pete Stahl
>Mark,
Are you the one that hooked up switches/lights to your garage door to tell you they were open/closed? Could you tell me how you did it? If it wasn't you does anyone remember who it was?
thanks, Pete
Re: Hey Mark Goodall
Yes that was me
>Sure. it was easy... all I did was...... hang on... I can't remember.
Hmmmm, bear with me for a second......
Okay, I put a stack of tiny rare earth magnets on the top corner of my garage door (steel). On the wall above it, about an inch away, I put a magnetic switch. I think I got it at Radio Shack. I'll take a look later to confirm. It's a low voltage switch that turns off when a magnet is near, and turns on when the magnet is moved away. I think it's similar to the kind that are used in home security systems. In fact, I may have picked it up at Lowes in the home security aisle. It came with two parts, the switch, and a matching plastic piece that has no wires but has the magnets inside. BEcause they are designed to be within 1/4" of each other to work, and because I needed to mount the switch a good 1+" away due to the size of the door, I used the rare earth magnets which are much stronger.
The switch is wired to a small battery box that has a couple of D-cell 1.5V batteries. Wires from that go through the ceiling and into the bedroom upstairs and to a 3V flashing LED mounted in a regular plastic wall plate normally used for a cable-TV coax cable. The 1/4" round hole in the plastic plate is about the right size for the LED.
When the garage door is down, the rare earth magnets are about 1" away from the sensor switch, and the switch is open (not on) so the LED doesn't flash. As soon as the garage door opens and the magnets are moved away from the switch, the circuit is closed, and the LED starts flashing.
THe LED isn't bright enoung to notice during the day when the sun is shining in the bedroom, but at night it's easily seen. As long as no one puts any junk in front of it ;)
Really simple actually.
Happy Woodworking!
