biscuit joiner
Dan Collins
>Friends: I have a Porter Cable Plate Joiner (model 557). It has a small blade to cut "FF" biscuit holes. To change to the small blade, a retaining bolt needs to be removed using a 5/32 hex wrench. I have removed it and changed the blades several times before. This time, the bolt would not budge. I spray some WD-40 on it to see if it would free up. That didn't help and now I have twisted so hard on the bolt that it is stripped. I now need a new bolt, but more importantly, I need to remove the stripped one. The Porter Cable repair shop is 50 miles away and I don't think it is under warranty anymore, plus they take forever to fix any tool there. Any suggestions on how to get the bolt out of there? Any ideas as to why it would have become unmovable. I don't think it overheated at anytime, nor has it been exposed to water, although my basement shop is fairly humid. If I can fix this, I want to make sure it doesn't happen again. Thanks. Dan collins
