OT computer problem
J Runchey
>After reading the thread on slow computers I thought I'd try to speed mine up, and in the process, I wound up with the fonts about half size. How do I get them back to a readable size?
OT computer problem
J Runchey
Re: OT computer problem
Chuck W
>Are you referring to the browser fonts? What settings did you go into to speed up your computer?
Dan Manturi
>It you were messing with the "display" screen (part of control panel), you may have changed resolution.
Hard to tell with little info.. You may also have changed something in Explore.
I'd start by checking display, but you also would need to change it to a lower resolution to get a larger font.
Dan
Dale Stansbery
>You haven't provided enough info to help much, but try using "CTRL +" to increase your browser font, or "CTRL -" to reduce the size. Several clicks in each direction will show you what it does.
J Runchey
>The fonts I'm talking about are in the favorites column and also in outlook express. As you may have guessed, I am an old timer and not the slightest bit computer literate. Hope this helps.
