Hearing protection...
Rob Hix - King George, VA
>Does anyone know of a manufacturer that makes something like the Peltor worktunes hearing protection but has an input for an MP3 player? I listen to a lot of podacasts and cannot remotely pause my listening device. I am missing a lot because I cannot hear while machines are running.
Thanks for the help,
Rob Hix
Re: Hearing protection...
Glenn Madsen near San Francisco
>Have you tried the ear buds UNDER the sound deadening ear muffs? I've used mine that way, when the mix of equipment used and expected people traffic was right...
Re: Hearing protection... *LINK*
David Sparks
>Hello Rob,
I use high quality shooter's earmuffs in my shop. I took the small speakers off of an old Walkman headset and put one inside each earpiece. You can then plug the setup into whatever kind of player you have. The muffs that I use have liquid-filled ear cushions that make all-day wear comfortable. The good thing about the way this works is that when the wires get broken ( as they invariably will ) I just take apart another cheap of Walkman headset and use the parts. I've included a link to the muffs I use.
Have a great day!
David
http://www.sportsmansguide.com/cb/cb.asp?a=279476
Peltor RaceTunes
Tony Sade (Charleston, WV)
>Is what you want-it has the port for use with an iPod or other MP3 player. I've got a pair and they work as advertised but, quite frankly, just slipping the iPod ear buds under any good muff would achieve the same result, I think.
Ron Hildreth, Alta, Iowa
>Glen,
I've tried that at work while mowing miles and miles of roadside ditches, as I wanted the hearing protection from the very noisy farm tractor I'm on, but wanted the enjoyment of some music to dimenish the drudgery. Worked OK for about three hours, but began hurting my ears after that. BTW- nothing different about my ears, just doesn't seem to be enough room under the ear muffs for the ear buds from the MP3 player.
Ron in Iowa
>Three hours is about my limit anyhow... ;-)
