Angled Wine Bottle Holder??
Ron Berlier
>Does anyone have information or location of plans for one of those single wine bottle holders that sit at an angle and seem to defy gravity?
TNX for the help -
Ron
Ron Berlier
TNX for the help -
Ron
Re: Angled Wine Bottle Holder?? *LINK*
Jennifer@Indy.USA
>Ron all you have to do is cut the end of the board you are using at 45 degree angle. Do the same angle for the hole you drill for the neck of the bottle to go through. I use a 2" forstner bit. You can either angle your DP table and clamp, or make a jig. They are really easy and fun to make and give away as gifts.
>I made a bunch of them. Thought they would be a good way to use up scraps and small pieces of wood and sell them for a few bucks. Must not have had the right venue, never sold one. Gave a few away. Might have some left if I did not throw them away. I could send you one if I run across them. I used a 1 3/8" forstner bit and a fairly sturdy jig or fixture for the DP. The plan on Jennifer's web site will send you in the right direction.
An interesting variation is to make the stick shaped like a fish with the tail down. Serve white wine with fish dinner.
PS....
>This is not as hard as it looks. Drill a large hole through the stick at a known angle, About forty five degrees. (That's the hard part. Tough to drill a large hole and not have it grab and run away. Clamp it done firmly) Then cut the angle on the ends to match the angle fo the hole. Make the stick "too Long' below the hole. Insert the bottle of wine and try it. If does not balance, trim a little off the bottom. Try again. Whittle it down until you find the sweet spot. Varies a little with the shape and size of the bottle. The hole size can vary also. Since the bottom fo the stick will be about an inch wide or more, you only have to get it close enough that the balance point falls within that inch. Once you find it, you can round it off and it will teeter on that point.
Ron Berlier
>Thank you both for the helpful information. I'm sure my efforts will be successful now.
