OT What makes a computer Slow or Fast?
>I have seen several people posting about new computers and I am becoming envious.
What part of the computer contributes to the slowness I sense.
I have a 1.7 Ghz processor, 512MB Ram and 80 Gig hard drive that is less than half full. Windows XP Home Edition. My son "upgraded" the graphics card so I don't know what that is.
So, When I go on the Internet (Comcast Cable Modem) what affects the speed the most? Does Ellis have his foot on the wire to the server again? Would more ram help?
I don't do any serious graphics or drawing like AutoCad.
I use Word, Adobe acrobat to convert files, E-Mail through Comcast and of course WoodCentral, so what aspect of the computer would I look at to speed things up? Either this one, or a new one?
Re: OT What makes a computer Slow or Fast?
Tom
>You should be ok with those specs. Not blazing fast, but fine for surfing and word processing. There are lots of reasons for a slow pc, some hardware, most software.
Right click on 'my computer', go to 'properties', then 'advanced', then the peformance button. Check the circle that says 'adjust for best performance' or something like that.
Download and install this:
http://www.download.com/ToniArts-EasyCleaner/3000-2094_4-10522776.html?tag=lst-0-1
Hit the 'startup' button and delete as many entries as you can. If you look down by your clock in the lower right corner you probably have a bunch of icons showing. You should reduce that. In the same program hit the registry button and delete everything it finds.
If you are using Norton or McAfee antivirus, don't. Uninstall them and use either AVG or Avast. They are much less intrusive and free.
Use Spybot, Adaware and Windows Defender to rid yourself of lots of junk.
Those changes alone will probably make a noticeable difference for you.
Chuck W
>you might try upgrading the ram by another 512 meg. Since you only surf the net your computer should be fairly quick. Sometimes spy ware, viruses and malware can slow a machine down. Also make sure the hard disk is defragged and run disk cleanup to empty out all unneeded files. And as was mentioned your antivirus program, Norton or Mcafee can slow things down.
David Yoho
>Most of the computers I come in contact with that people bring me with the complaint they've slowed down are due to several main reasons.
First thing I check, beyond the hard drive being defragged, is what antivirus and spyware programs they're using. If I find Norton or McAffee, I suggest a better alternative like AVG and Webroot's SpySweeper.
The next thing I look for is the amount of system memory installed. XP's sweet spot for RAM is still 1 gigabyte - Vista's seems to be two. On the XP machines I've worked on, bringing the total system RAM up to 1 gig usually does wonders for pepping things up. The only time I suggest more is if their graphics card, whether a stand alone card or it's built into the motherboard, is sharing the system RAM and therefore reducing the amount available to the operating system.
The last thing I see a lot of is computers running XP that they've had for three or four years and signs that all kinds of programs have been installed and deleted over that time. By backing up their important files, documents, favorites list, address book, and email mailboxes, formatting the drive and doing a fresh installation of Windows, downloading and installing all updates, and copying all the things I backed up before back - the computer runs as fast as it did when they first got it. Nothing beats a fresh install of Windows from time to time.
Those are the main things I've seen but there are others not worth going into here.
David
Ray SW Ohio
>David hit head on. I would add more memory, at least another 512 MB, and if still slow, do a clean install of Windows, or better yet. Linux. It's free! All you have to do is download it. Could make your pc a dual boot machine too. My 2�.
Bill Howatt
>Others have given a lot of the reasons the machine can slow down but in terms of your specific question about Comcast, the machine you have should be able to handle web traffic regardless of whether it is dial-up or high-speed cable/DSL.
Slow response to web-sites is usually because the server is bogged down or is throttled for any number of reasons. Also, your connection to any site gets routed and is not necessarily the most direct route by any stretch of the imagination. Sometimes some components in the route get bogged down. If things seem slow try leaving the site and then going back in - you may get better routing if that was an issue.
A fairly simple free program you can use to clean up your machine is CCleaner available at: http://www.ccleaner.com/ . A nice feature is that it lets you specify which cookies you want to keep on cleanup which means you won't have to re-login to your favorite like WC after a cleanup.
In general terms what makes a machine fast depends on what you want to do with it. Plenty of RAM is a necessity so it doesn't have to start swapping things out to the disk. If you hear lots of disk activity and programs are very slow to load then this is the problem.
For graphics and especially games, a high-end graphics card will make a big difference. You will take a bit of a performance hit if you buy a Celeron instead of a P4 at the same speed rating. This is mostly due to more internal cache in the P4.
For what you describe as your use, I'd say your machine's hardware is fine. The machine I use for internet access, email and some graphics is an AMD Athlon 1.2GHZ with 512MB RAM.
BTW, I used to reload W95, W98 at least once a year to get the speed back. I have never found it necessary to reload XP and the machines have been running for years.
When I go to My Computer there is no
Don henthorn
>way to go to Properties in that screen. How do you do it?
Re: When I go to My Computer there is no
Dan Donaldson
>Don't go to the screen. Right click on the "my computer" icon and properties will be one of the picks.
Dan Donaldson
>Agree that the first thing that I would try is more memory. That usually is the best thing to speed up a slow machine. As stated earlier, if norton or mcafee are on the machine, get rid of them and go to AVG or AVAST. Both work well, are free, and have much lower overhead. The last thing would be a fresh windows install. That can help, and , if Norton is on the machine, might be the only way to totally get rid of it.
I like Linux. The computer that I am typing this on is running Linux and is not dual boot, (I only have one computer running Windows and that is just because of a couple of legacy programs that my daughter uses) but that said, the hardware for this box was selected with the express purpose of being Linux compatible. Linux can be easy or hard depending on your hardware. With the "wrong" stuff, it can be a nightmare to get everything working properly. This is especially true if you have a laptop. (mine is not)
This system has:
Intel 1.86 Ghz duo core with 4 meg L2 and the high speed side bus
2 gig Ram
Nvidia 7300 LE video card
2 sata II drives, one 250 gig and a 500 gig
It runs nice on Linux. Would probably run Windows well also, but I haven't tried it.
Before you do anything
>Before you waste any time doing anything to your PC and possibly make things worse, make sure it's not a speed issue outside your house.
Go to my www.outerlimitsconsulting.com website and click on the [SUPPORT] table and scroll down to the middle where you see the speedometer and Speed Tests.
Test your speed and make sure that the slowness you sense is not a result of a slow internet connection.
These days, when people mention slowness, rather than a virus or anything like that, it's often just the speed of their internet connection.
Then if it's not that, check for viruses, etc. as others have mentioned, or cick on the links on that support page to check your virus software and make sure you've got WindowsDefender. AVG+WindowsDefender or NAV+WindowsDefender is adequate in 95% of the cases.
If your internet connection is adequate, and your PC is clean, try defragging your hard drive, and also do a disk cleanup which will erase your internet cache, etc. Don't turn on disk compression.
Let us know where you stand after that.
While adding RAM is the single best and least expensive hardware upgrade to improve performance, your 512K is absoultely fine for WindowsXP and simple web surfing, assuming you don't have moer than a couple of windows open at once.
Happy Woodworking!
Re: Before you do anything
Dan Donaldson
>I get weird results on basically all speed tests. I just ran the first one on your website (it is consistent with all of the others that I have tried) and got 18742 up and 2792 down, which seems to be faster than I would expect. I made sure to clear the cache before I ran it, and tried a couple of different servers with consistant results. The speeds for my downloads seem to match fairly well with these, but it does seem awfully high. I am on a comcast cable system on a Dell xps410n running ubuntu linux. Any thoughts?
Thanks, and more questions?
>Thanks Guys, great responses.
Some more questions.
I like to have several programs open and minimized. WoodCentral, E-mail, Spider Solitaire (shame on me), and often Word. Does leaving them parked at the bottom of the screen really slow things down? (Solitaire slows me down, but that's because I play it.)
I have a number of programs in my list of all programs that I don't know anything about. My Software Choice, Valve (empty) And PrintMe Internet Printing. Should I remove them? I am fearful of removing them because I don't know anything about them. Also, a program called "Veiwpoint" pops up occasionally asking to be updated. Again I don't know what it is and am not aware of ever using it, but it's not listed in All Programs. Should I remove it and How?
Can I add the Ram myself? What do I need to know? Seems it should match what I have now (SDRAM memory). If there is an empty slot, do I just plug it in and Reboot or do I have to somehow Install it from the keyboard? (Type in "Look what I brought you?")
Anything else running
>I always turn off all other computers and then make sure that there are no other processes running on the test computer to compete with the connection test. Then I run tests againt various servers, to make sure that I'm not getting a reading that skewed because of the server. Then if I don't get results I expect, I disconnect all my client's computer from the network and run with only my laptop (which is tested clean and funtioning perfectly) on the network to see the results.
I have never seen many amoloies with the results if I follow all that.
But now that I think about it, most of my clients have either a T1 or DSL, rarely Cable. Doesn't the whole cable technology mean that you are sharing bandwith with your neighbors? If that is the case that perhaps connection speed testing is pointless on a cable conenction.
Happy Woodworking!
Re: Thanks, and more questions?
>"I like to have several programs open and minimized. WoodCentral, E-mail, Spider Solitaire (shame on me), and often Word. Does leaving them parked at the bottom of the screen really slow things down? (Solitaire slows me down, but that's because I play it.)"
Even if they are minimized, they are still in the active memory, so they slow things down.
"I have a number of programs in my list of all programs that I don't know anything about. My Software Choice, Valve (empty) And PrintMe Internet Printing. Should I remove them? I am fearful of removing them because I don't know anything about them. Also, a program called "Veiwpoint" pops up occasionally asking to be updated. Again I don't know what it is and am not aware of ever using it, but it's not listed in All Programs. Should I remove it and How?"
Viewpoint is a media player. I don't have it, but if you do a search, I'm sure you can find some removal instructions.
"Can I add the Ram myself? What do I need to know? Seems it should match what I have now (SDRAM memory). If there is an empty slot, do I just plug it in and Reboot or do I have to somehow Install it from the keyboard? (Type in "Look what I brought you?")"
Yes, you can add the RAM yourself. Upon the advice from some posters here, I used the Belarc Advisor to tell me what memory I had. Many of the memory sellers have on line programs which will analyze your memory and tell you what to buy. All I've ever done was unplug the computer, put the memory in, plug it back in and reboot.
Steve in Fresno
>Hi Barry,
The programs you listed could be nothing or they could be spyware. The best way to find out is to Google the name. There will be plenty of info about each file. As was said before, download ccleaner, it will help with removing unused programs, and fixing conflicts. And its FREE.
Installing RAM is really easy usually as simple as sliding it into a slot,and rebooting. The computor will see (automatically) you've bought it something new, and will will purr like a kitten with it's tummy full of warm milk.
Bill Howatt
>If you have programs or anything for that matter that you don't know what it is, put it into Google and search it out.
Unless your HD is getting full you don't really have to sweat about programs being stored on the disk. Just being on the disk isn't really a performance hit other than maybe they are causing the disk to be fragmented which will result in slightly slower loading.
Personally, for what you say you are doing on your machine I don't think adding more memory is going to do anything for your performance. Letting Word or anything else sit minimized isn't going to be any performance hit. The reason is that if the machine needs the memory it is occupying it will swap parts out to disk and if you aren't actively using the program you won't even notice it. A small amount of memory is used in this case just to tell XP that the program is present, status, etc.
On my 512MB 1.2GHz, AMD I just loaded up Task Manager, FrontPage, Quattro-Pro (spreadsheet), WordPerfect, PaintShopPro8 with photo and Internet Explorer 7. Repeated my internet speedtest and it was unchanged. In Task Manager (start by Ctrl-Alt_Del)Performance you could see the swap file increase very slightly as these apps were started.
The only time you really a see an obvious degradation in performance is when you don't have enough memory to do a task and the system is continually swapping RAM out to disk and back. Probably the most common case of this happening is trying to manipulate a large (100+MB) graphics image. With the image itself and copies of it being open simulataneously (for changes, undo buffers, etc) the RAM utilization can be very large. This degradation is very obvious.
Making sure there is no spyware running is a good idea but in many cases the load it presents are vastly over-estimated.
Bill
Don Pierson
>It is beyond the scope of the human mind to go into the all of the factors of "Computer Speed". That said there are a few general rules. Money is well spent on adding as much RAM as your computers design allows. MS Vista needs a minimum of 2gig and 4gig is better. The hard drive is mechanical/slow bottleneck and additional RAM reduces the disk access. My experience with my previous IBM Thinkpad, 3ghz pentium, XP, dialup became unbearable. Over time it became loaded with "services" for numberous software components to where the bootup took minutes. With my new Gateway, 2gig RAM, QWest dsl, MS Vista, I press the power switch to take it out of the "sleep" mode, type in my passward, click on the Explorer icon and my home page is on the screen in 30 seconds flat total time. I think the major factors are Vista, RAM, DSL in that order. I think Vista as some design elements that reduces the load time of things from the registerery,etc. Whatever the algebra of the speed equation I love the 30 seconds! Don't I long for the days when computers had vacuum tubes, rotating drum memory, and you wrote 4F as the hexadecimal code for multply...NO!!!!!
Jason Roehl in Lafayette, IN
About cable internet...
>Yes, with cable you are sharing bandwidth with your neighbors. However, at least with my provider, I don't see much of a problem too often. Late afternoon and early evening are usually the worst time if there is an issue. I'm in Lafayette, IN, so if I do a speed test to either Chicago or Louisville (close major hubs), I get about 90-95% of my advertised download speed (10Mbps). Speed tests to Atlanta or San Francisco (distant hubs) yield significantly less, like 3-4Mbps. I'm a little nervous, though, because my provider, Insight, recently sold this region to Comcast. I have heard very bad things about Comcast, so we'll see what happens. No outward changes have taken place yet.
Realistically, if a server on the Web is good, I can download large files (20+ MB) at a rate of about 0.5 to 1MB per second. That means that an Adobe Reader update of 28 MB hits my desktop in about 30 seconds usually.
If you're into tweaking, broadbandreports.com has some good tweaks of Windows settings that allow you to optimize your computer for the bandwidth you're supposed to be getting. I've done that in the past and seen marked improvement (or I could have hired Mark and seen Goodalled improvement...hahaha).
Jason
Re: Anything else running
Dan Donaldson
>I tried several servers and got similar results. Cable does share bandwidth, but that usually has the effect of slowing things down, not speeding things up. As I mentioned, the download results that I get when I hit a good server seem to verify that it is fast, but I am just wondering why. It is as if they have turned off the throttling that they do to limit your bandwidth. I make sure to clear the cache, and any services that I have running would slow things down, not make them faster. Not that I am complaining, mind you...... ;-)
Dan Donaldson
>Just be aware that many computers require that the memory modules be replaced in pairs.
Re: About Comcast cable...
Glenn Madsen near San Francisco
>Pulling everything together to transition from one, relatively independent operator, into a combined national carrier, can be a pain, for customers and engineers.
@Home was one of the first cable internet providers, and we had them since their second city rollout. Three or four companies later, and we're still there, although it's more than we need. Comcast generally gets their systems together, although it's not immediate, and may not be the best thing since sliced bread. It's still as good as anything else available here.
Except when the kids down the street are downloading movies, or playing fancy role-playing games, or ...
>I looked inside my computer and I don't see any empty slots. There appear to be three slots that all have a Chip(?) in them. I guess this means I would have to remove one or two and replace them. Is there a web site that would explain this to me?
>What I heard bad about them wasn't just about their cable internet, but their cable packages as well. I'm reasonably satisfied with the package I have now from Insight, I would like to see a little more HD content, but they just added a couple HD channels that I would have had to pay extra for just a few weeks ago, so they are improving, if only slightly. I wouldn't mind if the prices came down a bit, though....
Jason
That's old school...
>...from what I've seen in the past couple years, that is generally no longer the case. Many computers now come with 3 RAM slots on the motherboard, with 2 of them filled, and no pair requirement. In fact, the last 2 Gateways I have owned (bought in '01 and '06) allowed me to insert MMs one at a time.
Jason
Re: That's old school...
>I just ran Belarc on it and I have 256, 256, and 128.
I went to another site and they said the computer I have can handle a max of 0ne Gig.
If I buy two 512's and insert them Can I move one of the 256' to the third slot or would that put me over the limit? Or can I buy one 512 and replace the 128 with it?
On the other side of the page, the unit seems to only recognize 256 in the Belarc analysis. any suggestions?
