dumb planer question
Trish B.
>Gentlemen and Ladies, this may seem like a silly question, but is it ok to run plywood through a planer? Or will the glue damage the knives?
TIA and I hope everyone is enjoying their holiday weekend!
Trish
Trish B.
Trish
Re: dumb planer question
>Interesting question. If you did this I think it would ruin the plywood. Plywood is supposed to be "balanced" construction. In other words, the outer two plys run in the same direction and the next layer inward run opposite them and so on. Even if you could plane off one side without damaging the cross grain ply, the plywood would be unbalanced and most probably warp. Also, the inner plys are not nearly as "pretty" as the skins and you would reveal these inferior surfaces, making it unlikely you would get a cosmetically acceptable appearance, even if you took the same amount off each side.
Another question is Why? Why buy plywood thicker than you need and plane off and throw away part of it?
And, I agree that the glue is likely to be tough on your knives.
OTOH, I have not done this and have no direct experience, so I really don't know. If you try it, let us know what happens.
Jesse in New Mexico
>Hi Trish,
I think Barry nailed it. Planing plywood is like trying to teach a pig to sing - nothing good comes of it and it annoys the pig. ;^)
If you could give us more info on what you want to accomplish, maybe we could help.
actually...
McKay
>I have done this a number of times if I have needed some bending ply and have not had any. Kerfing leaves facets and planing just allows the plys to bend. By setting the cutter to cut the wood and not the glue joint, there is no difference in this type of planning and planning solid wood. More damage will occur to your knives hitting knots than with planing plys. Now mdf is a different "pig" so to speak.
Robert R Clough - Thorncraft
>My reply is right out of The Hunt for Red October.
"Sure you can. Why would you want to?"
Could be Trish is more interested in
Don henthorn
>jointing plywood than surface planing. While I have done it on occasion, I wouldn't do much of it because it is hard on knives.
Well put, it's a good exercise
Lee Grindinger
>While I think that glue is pretty hard on the knives I, too, have planed plywood for a number of reasons, not the least of which is to make my own "Wacky Wood", a decent bending plywood.
But, Trish, removing plys will have a negative effect on the integrity of the plywood.
Lee
Trish B.
>Hi guys, thanks for the input. I asked on behalf of a friend, who is using cherry ply (banded with walnut) as applied drawer fronts. The pieces are 1/8 too thick (the drawers protrude from face frame) and he wanted to plane the ply down to make flush drawers. But he has now decided to keep them as is, for a design "feature."
