not quite true, and why you smell it
Michael Dresdner
>Sorry to be a prig, but there are no solvents in pure tung oil and there is no reaction product that can 'off gas.' I think what Howard meant to say was that the wax can slow down the cure of the oil, and that is true, but there is nothing in tung oil that can affect the cure of the wax. That's because wax 'dries' solely by solvent evaporation, and pure tung oil cures solely by oxygen polymerization. Unless you mix the two while wet, the oil has no effect on the wax. Wax, on the other hand, can slow down how quickly oxygen can get into the oil to cure it, and that can slow the curing process, so his advice is right even though his explanation is slightly flawed.
For the record, the term off gassing refers to gasses created as reaction byproducts of a chemical reaction in finishes. Hydrogen is the most common one by far in finishes.
That naturally raises the question "So if it is not off gassing, why can I smell the wet tung oil?" The answer is that until it cures to a solid, molecules of tung oil are able to escape into the air much like water molecules become water vapor in the air. As long as they are airborne the molecules can reach you nose and you will smell it. Yes, that means that when you smell feces your nose is actually taking in molecules of... oh, never mind. No need to go there.
