OT set cookies
OT set cookies
OT set cookies
Howard Norman
>OT-set cookies, trying to solve problem on new computer-ignore message
Re: OT set cookies
just FYI
Dan Donaldson
>You can set a cookie without having to actually post a message. Start a new message, then do a preview and exit. That will set the cookie.
Re: OT set cookies
ginger snaps
Re: OT set cookies
Re: just FYI
Howard Norman
>I know that you should be able to do a preview to set the cookies but I tried it twice and it didn't work. Looks like I have a cookie setting problem.
Howard
Re: OT set cookies
Re: just FYI
Tom Pilsbury
>If you are using Internet Explorer click on Tools, Internet Options, Privacy, Advanced. Set your options there. If you want to block/accept cookies from certain sites use the edit button at the Privacy box.
Re: OT set cookies
Re: just FYI
Howard Norman
>I am using Firefos 2.0, I have never had this many problems before in setting up a computer with cookies. I went and specifically set up
to accept cookies from Woodcentral. It still won't do it. I seem to recall that someone else had this problem in the past but don't remember the solution.
Howard
Re: OT set cookies
I had a little fight like this myself,
Rod Peterson -- Ormond Beach
>when I first set up the new computer and Firefox. I don't know that one or the other was the problem, per se, since changing everything eliminates the opportunity to isolate the cause. In any event, one of the things to make sure you do in this case is to delete all the WC cookies and then do the message preview that Dan suggested. The preview alone usually works, but occasionally you have to clean house. And I also agree with Dan that it should never be necessary to send a blank “cookie” message.
Rod
Re: OT set cookies
Re: I had a little fight like this myself,
Howard Norman-Prescott, AZ
>Rod, I have done all of that and there are still problems. I have decided to forget it for the rest of the evening and am using my laptop for this session. Will tackle the problem again tomorrow.
You have given my an idea. Tomorrow I may try IE as the browser and see if the problem continues. I certainly don't intend to use IE as my browser but it might be interesting to see if the problem exists there also.
Howard
