Sears did me right, next stop Stihl - but a ???
David Breth
>First, the Sears saga. In '06, I purchased a gas craftsman for $160. It was nothing but failure on top of failure. It was serviced three times, and I learned they would issue a store credit after three services, so I tried to go a step further. With a little patience, and acting like a gentleman, the store manager gave me a cash refund rather than a store credit. Sears may not be the leader in lathes or chainsaws, but I'll tell you what, I can not think of a time ever when Sears did not ultimately make a situation right with me.
Now, on to Stihl. As fate would have it, I live about three miles from a dealer. promotions at the moment are going on, and I'm leaning toward the MS 250 or MS 270 with an 18" bar. My question is this - Is the Quick Change Adjuster a worthwhile feature? In the pictures it looks like a piece of plastic waiting to break, and I'm wondering if it will really hold the chain in position or if it will loosen up all the time.
Also, if anybody has comments on my choices of model, I'd like to know. I'm not harvesting trees, and I'm not the most prolific turner you've ever seen, but when I need a chainsaw, I need it.
Thanks for your time. I haven't posted much lately, but I did just turn my 100th bowl, and will post that as soon as the finishing is complete.
David B.
Re: Sears did me right, next stop Stihl - but a ???
Thomas S Stockton
>I have an ms250 as my second smaller saw and like it it is real light and has plenty of power for it's size. The quick adjust chain thing is in my opinion a waste of money it is not that hard to adjust a chain and only takes less than a minute.
Tom
Jim Dillon
>David,
I agree with Thomas on this one. I have an older Stihl 16 inch (plenty for me) and chain adjustment (if needed) takes only a minute. I actually only have to tweek the chain tension on a new chain maybe once when it is first used, then never again.
Jim
John in MD
>I've had the 250 with an 18"bar for about a year and a half now -
starts on the second pull every time, - Light enough to use all day, and plenty of power for the occaisional user.
I'm not doing logging - just cleaning up some errant limbs, and the occaisional downed tree around the property. I've taken down some decent sized trees, and made more potential bowls than I have time to turn. The saw runs like a champ, - I abuse the heck out of it, and it always comes back for more.
Not sure what the Quick Adjuster is about - I suspect its an extra doohickey some engineer came up with for their non-professional line of saws as a marketing gimmick.
Get the 250 without the Quick adjust and you'll be happy.
-John-
Howard Norman-Prescott, AZ
>I agree with the other guys, adjusting the chain on a chain saw is no big deal and doesn't have to be done very often.
Howard
Kirk D.
>I own a older 026 that has cut a mountain of wood. If I were you I would get a model that the air filter screws on. You will need to clean this all the time with compessed air to keep your saw running good. Some of the new models have snap on air filters. If you can spend a little more money and get a 026 with a screw on air filter. I don't have enough experience with those quick adjust bars but have used a saw with the snap on air filter and would not buy one. I would stay away from gadgets and buy a real Stihl that you can always count on. The extra cost is nothing compared to the frustration of cheap parts breaking.
JKJ in East TN
>David,
I have had a 250 for years (with a 16" bar) and it is an excellent saw. I love it for limbing and bucking and hacking out turning blocks. I like it because it is lightweight and well balanced, both which contribute to safety. But at the same time it has plenty of power. (It also fits nicely on a 4-wheeler to get to downed trees!) I use a larger saw (with a 24" bar) when necessary, but the 250 is my favorite.
Chain tensioner
Dave Peebles Lyons, Ohio!
>Hi David,
I have a Husqvarna 346XP for my gas saw. But I also have the Stihl 180C electric that I use in the shop. It came with the quick adjuster on it. It works like a charm. Not cheap feeling at all. But as the others have said, it only take a minute to do it with the wrench. I just wanted to let you know I like it on the electric.
Best wishes,
Dave
David Breth
>I thought I posted this under "turning". Couldn't find it again!
Thank you all for your responses. I greatly appreciate it. I will definitely look into the air filter situation on any of the models I look at.
Thanks once again!
David B.
John McGaw
>I can endorse the Stihl without reservation. I've never owned or worked with one that didn't work perfectly. Right now I have an older 026 which used to be a "Farm Boss" or something like that. It had a relatively long bar and narrow chain with a non-standard pitch. I discovered early on that one cannot buy a rip chain that would fit so I replaced the bar and drive sprocket at my first opportunity with a "standard" 0.375" pitch and a slightly shorter bar. Having a rip chain can make all the difference in the world when it comes to reducing a large log to usable chunks.
>I was able to get a rip chain for my old Farm Boss through a nearby arborists supplier, who had to special order it from out west somewhere.
Clint
Troubleshooter
>I have had one for three years with the chain adjuster. It works good. When the saw chain gets hot and stretches you can adjust it without going hunting for your wrench.
