Oneida Air 2 hp Super Dust Gorilla � mini review
>I got this system a while back. As my shop and I were still 100 miles away, I only had a general idea where I wanted things. I ran the electrical and mounted the unit on the wall and left it at that. As I now the time to build the shop, I finally have installed the ductwork and I have been using the system.
Assembly � the assembly was interesting. All of the pieces are substantial and well made � and heavy. I mounted the bracket on the wall and hung the cone on the bracket. I then got the barrel up on the bracket and cone and bolted it together. I suppose if you had the room and the help, you could lift the entire cone/barrel assembly onto the bracket � but it would be interesting. I then lifted the impeller and motor assembly on top of the barrel. The motor is a 2 hp Baldor, wired for 220 V. It is quite heavy. The filter assembly was relatively easy to install.
Ductwork � the ductwork was a chore. I had already put up the grid and the ceiling tile to finish off the room. I ran a length of 7� pipe out of the impeller and put a 7� elbow at the end of the length. I ran another piece of 7� pipe out of the elbow into another 7� elbow. I have a 7/6 reducer at the end of that elbow. All of the ducting is 6� ducting. The main line has several wyes in the line. The first wye goes to another wye and then to my band saw and my lathe. The next wye goes to another wye and then to my table saw and my counter (compound miter saw hood or bench). The next wye is a reducer (6 x 6 x 4), which goes to my jointer. The end of the main line is an elbow, which then goes to my router table. A thanks to the two Jim�s who suggested metal tape for the elbows. I�ve taped the elbows and the amount of leakage is minimal.
Running � Oneida Air was running a special on the remote start (you got it free at the time), so I got the remote. It comes in very handy. Noise � the cyclone is somewhat noisy (80 db or so), but not too objectionable. As I am usually running a piece of power equipment, I usually wear ear protectors. The cats object to the noise when they are in the shop, but will often stay in the adjoining room.
Power (suction) � I don�t really have a way to honestly measure the CFM or suction at this time. Objectively, it does manage to take the majority of the sawdust from the tool. The following pictures show my table saw after ripping and cross-cutting over 30� of poplar and my router table after routing rails and stiles for 20� of length.
What would I do differently? Maybe I should have put up the ducting before I put up the ceiling grid and tile. I don�t know. The 5� sections of ducting managed to fit up there reasonably easy. It was nice having to have something to rest the ductwork on though J.
