Re: Shellac, How many coats?
Glenn Madsen near San Francisco
>Have you 'cut' the shellac? If so, you're likely about 1/3 of the way there. But it's up to you, really. When it looks right, you can stop.
Seal coat is fine. It's dewaxed, and a little lighter color and cut, but good shellac. I've used it on a number of projects. It's available at a lot of places.
I'm not a lacquer user, so I have no opinion on the overcoat. I did one TV stand for my youngest son, brushed Deft, and disliked the results enough to give away the last of that batch of finish. I disliked the smells, too. Several coats of wiped on 'regular' shellac, follwed by furniture wax, would be fine in our home. But we don't use alcohol, so that's not a problem for us. What I read, though, is that strong alcohol in a drink would STILL need to sit overnight to cause a problem. And repair would be pretty simple thereafter.
Take pictures?
