Performax 16-32 Plus Ceramic Guides
Doug Reynolds in Seattle
>My Performax 16-32 Plus came with ceramic conveyor belt guides. Someone recommended I remove them because he claimed they don't work and destroy the belt. Any comments? I just replaced my original belt after five years of occassional use. It started to separat at the joint and, over time, continued to separate.
Re: Performax 16-32 Plus Ceramic Guides
>I can't actually answer your question but that has never stopped me from commenting before.
I have an older (1994 I think) American made Performax that does not have the ceramic guides. At least I am not aware of them if they are on there. I bought mine used and the belt was somewhat battered when I got it. The previous owner had apparently sanded a bunch of really thin stuff and sanded the grit off the drive belt. At least That's what I think happened and I'm sticking to that story. The belt did not track in the center and I tried to adjust it. It tracked off to one side after I stopped watching closely and tore one edge off. (It was already damaged.)
I put on a new belt. It tracks over near the motor and control box, but does not seem to be hurting anything. I have thought about adjusting it to track in the center, but after my experience with the older belt, I am resisting the temptation. It works fine and I am trying to convince myself to continue to leave well enough along.
It seems to me the ceramic guides my be dangerous and tear up the belt, but I have no experience other than mine works fine. Sometimes less is more.
Incidentally, if you want to sand thin stock and you hear the sand paper "snicking" on the drive belt, what I do is use a backing board. I sand a board big enough to support the work piece and then use double stick tape to adhere the leading edge of a piece of homemade veneer to the board and then sand it. I have successfully sanded pieces as thin as 2/100". For stuff that is 1/8 or a 1/4" you can put a stop on the backer board and let it push the piece through. However, if the pieces are flexible and the work piece slips over the stop it might shoot out of the sander. It might also bind up and try to climb over the stop.
Sue McLam in Orange, VT
>Doug,
I've had my 16/32 since July of 2000. I've always had the ceramic guides on and they cause no problems. I'd recommend keeping them on. I've never had belt tracking problems.
Sue
David Sparks
>Hello Doug,
I didn't have the ceramic guides when I first got my Performax 16-32. I had a lot of belt tracking problems and spent a bunch of time trying to tweak the machine. (I think I bought my sander shortly after they came out). I told one of the Sanding Catalog reps about it at a woodworking machinery show. He gave me a set of the ceramic guides that they had just developed for the machine. I installed them and have been using my sander for many years with no problems. The only damage on my belt came from the time I used it before installing the guides.
wb4jtb
>I have the Ryobi knock-off version, so this may not be applicable. I was having major tracking problems until one day when I released all the tension on the feed belt and started over. It seems that the tension had increased through successive adjustments and must have been bowing the feed rollers. Tracks perfectly now that the tension is the minimum necessary to make it work.
---Scott.
Scott Crumpton
>Oops, that previous post should have been under my name. Hopefully this one is. Have no idea why the computer keeps stuffing my call signe in there.
---Scott.
