Using Windows XP...Word 2003 and I've tried to open a few word docs I have saved and they will not open for me. They've not ever been a problem in the past and now this?
>Scott, I'm at a loss as to why your saved documents won't open using MS Word (provided they weren't created in a newer version). One idea you could try is to see if they will open with Windows WordPad. If they do, there might be something wrong with your installation of Word. If they don't, perhaps the file is corrupted or the file extension changed to something neither program recognizes.
>If possible, try to open a problem document on another computer or send one by email to someone that can try. This will show whether the problem is with the document itself or the Word installation.
I assume you've rebooted. That will clear out the memory. Sometimes a program does not exit cleanly and leaves part of itself in memory - this can interfere with operation. You can also check the processes in Task Manager and orphan instances of winword but it is simpler and safer to reboot.
