>Okay, I had a little run in with my table saw blade. It could have been alot worse, but it was bad enough! I have always been cautious but now I want to be even safer. I need suggestions on safest accessories for pushing wood through but also having control over it. I was using my dado blade to make some wood trim and my finger got too close to the blade. What does everybody out there use to push something like that through, but able to keep my fingers out of the way. I would like suggestions on the best type of feather boards and "hold down" devices that attach to your fence or some part of your saw. I have a delta unisaw with a 52" biesemeyer fence system and the bench dog router table. Also what about power feeders? Any help would be greatly appreciated. Thanks, Bill
>The best I have found is the GRRRipper push block system from MicroJig. It can be adjusted for 1/8" rips or 1" dado cuts. It is very secure, grips well (you need to clean the rubber contact pads every now and then), and keeps firm downward control without exposing the operator to (much) danger.
Buy two, and buy the deluxe version so you can more easily keep them balanced and be able to "walk" hand over hand when working with longer pieces.
As with any tool or accessory, you still need to be careful. Hopefully, if my GRRipper does ever slip, my new SawStop will prevent too serious an injury.
>Sorry to hear about your injury. I've never had an table saw injury but have seen and heard about accidents that make me cringe everytime I think about them. Without knowing the details surrounding your incident it's kind of hard to speculate what might have helped you prevent it in the first place.
Some things we do to lessen the risk of using a dado blade:
- use zero clearance inserts (we have one for each width of dado in 18" increments
- on procedures other than regular dados down the middle of the board we try to plan or script the operation. That is try to determine if removing material might make the piece want to "tip" or become wobbly as the dado or rabbet is being cut.
-when cutting rabbets use a sacrificial fence so piece being cut is not between fence and blade.
- make deep dados in several passes increasing blade height each time.
-and just my personal preference, wobble dado blades unnerve me.
>Bill I have 2 rules concerning the table saw. My hands never go over the saw insert. I make sure my hands avoid that area. The second thing is I use push sticks always. I never push wood within the area of the blade with my hands. Once you start using push stick for everything they become like second hands so they don't feel clumsy. I try to stay a little scared of my saws and jointers. I figure as long as I'm a little leary of them I'll be more careful.
>I�ll cast another vote for the GRR-Rripper. It�s the best safety accessory I have. I much prefer it over my home-made push sticks and holding devices. And I agree with Joe�s suggestion that you should get the premium version. The accompanying DVD is a bit tedious but it�s thorough and quite worth watching.
My GRR-Rripper is a little chewed up. I don�t mind � it means my fingers aren�t.
If the price is a bit high, you could make something similar, and perhaps use a mouse pad as a gripping surface. But I figure the real thing is pretty cheap insurance.
Charles (whose digit count is still 10. Or 20 if you include toes.)
>Bill Sorry about your accident. The best way to avoid making mistakes is to learn EXACTLY what happened. What you have told us is like saying I was driving a car and Bamb.
Why don't you tell exactly what you were making? Please answer all of the following questions
1. What were the dimensions of the piece you were feeding?
2 How wide and high was the dado, and how far from the fence?
3 What feeding method were you using? Where were both hands?
4 Have you examined the piece that you lost control of. This is a piece of forensic evidence, and will hold clues to what went wrong. Some people just go blank after an accident, while others re-live it in slow motion.
I have two friends who have lost parts of their hands using a dado on the TS, so anyone who shares the details of their accident can help someone else from following their example, so please tell everything that you can about what you were doing, and maybe the collective wisdom of the forum will shine a little light on the hazard that you missed.
I hope this does not sound like I am jumping on you, but I just think this is the best way that accidents should be addressed. Thanks Keith
>And glad to hear it wasn't worse. Bottom line is to use at least one push stick (I use two, one behind the blade acting like a splitter), doesn't matter if it's a fancy commercial model or something cut out of scrap plywood, they all work, and they all keep your fingers away from the blade. If you make your own, take the time to round the edges with a router, makes it a lot more comfortable to use and you're less likely to do without.
>I love my Grrripers. I think they are the best safety widgit invented for the TS. I have two -- chewed up the legs on one of them pretty bad and replaced them just a couple weeks ago.
>I have used many, many different push sticks, blocks etc. I purchased two deluxe sets of the Grr-Ripper's at a wood show in Indy 3 or 4 years ago. They allow you far more control of the material than ANY other method (other than a power feeder). I have the micro splitter installed on my insert in my Unisaw. I was cutting some Eastern Red cedar last week and found it was reaction wood. The wood warped so badly and bound on the splitter so tight I had to shut the saw down and remove the board - still bound on the splitter in the insert. It took a chisel driven into the saw slot to free the splitter. During this entire process, I never felt at risk, as I was holding the board down with the Grr-Ripper until the saw was completely stopped. I use mine every time I use the table saw unless I am using my sled or miter bar, and sometimes even then. My Rippers have several slots where they shouldn't (due to improper setup or reversing the ripper from the way I set it up). I am looking at getting replacement parts or just buying a couple more. Used properly, they 100% prevent kickback and are 100% effective in keeping your hands clear of the blade.
>Well, first off, if you can afford a better saw, like a European machine or a Sawstop then buy it. It's actually way cheaper than an emergency room visit.
If you can't afford the new saw buy yourself a couple of those extra long push sticks that Felder sells. They are great. If you don't have a splitter on the saw make sure to get one, and get a guard on the machine and use it.
I also have a power feeder that I use on my Felder saw and it would definitely have saved your fingers some trauma. Yesterday I ripped a few hundred feet of 3/4" strips of maple without any grief using the feeder.
