Re: Domino or Leigh M&T
Chad Pearson
>I have both and I don't have anything bad to say about either one. They do have their respective advantages however.
Festool Advantages
1. The Domino is really quick to pull out to do a couple mortises. I find myself doing the mortises on an as needed basis during the course of the project. The FMT takes a little bit of setup time and thus I would batch cut everything at once. This is especially true if you don't have a dedicated router set up for the FMT.
2. Portability - The Festool can be brought to the work.
3. Mortises can easily be made in a field (e.g. in the middle of a bookshelf panel)
4. The Domino collects 99% of the dust. The FMT always makes a mess, even with the vac hooked up.
Leigh FMT Advantages
1. Using the fence I can batch cut a bunch of M&T's while only measuring once. The Festool has some of this feature through the stop pins but it really isn't the same.
2. The Leigh is really nice for doing multiple angles (e.g. chairs). I haven't yet tried multiple angles on the Domino...I think it will work well but I can't really say as yet.
3. You don't have to buy the tenon stock and it is a true M&T rather than floating. There's just something cool about that.
4. The leigh allows you to make a very wide selection of tenon sizes. If I want to make a 1/2 inch wide tenon I can. The Domino would require lots of little mortises for the same strength. The FMT also allows you to go very small (I have seen matchsticks with M&T joints on display at a woodworking show).
These are my impressions so far. Keep in mind I am just a hobbiest and so my tool usage has not been heavy. I have had the FMT since just after it came out and the Domino for about 3 months. I have no intention of selling the FMT but at the same time I don't expect to use it nearly as much as I did before.
I would be interested in the opinions of others as well.
Chad
