THE WOODRAT IS BACK!
Shellac Finishing Questions
>I have made a Huntboard of heart pine. Put on a coat of Zinzers Seal Coat. I like it, but have several questions.
I coated everything, Inside the cabinet, drawers and all. The drawers fit nicely and slide smoothly before. I put them back in place to show off the piece to a friend. They are rough and don't slide well. (The shellac was dry for several days) Is this just a matter of buffing or fine sanding and waxing the drawers?
Also, I used the shellac because I wanted the drawers to have some finish, but the last piece I did I used lacquer and It still has an odor. The shellac lost its odor quickly, so that was what I wanted. Now do I apply more coats to the drawers?
I want a tougher finish on the exterior so I am thinking of lacquer on top of the shellac. (Not on the interior, avoiding that odor thing again) Do I just lightly sand the shellac and start with the lacquer? Horror of horrors I have a few lap and brush marks in the shellac. Do I just buff them out with sand paper or steel wool or do I try to blend then with alcohol or do I apply another coat of shellac?
Re: Shellac Finishing Questions
Kneale Brownson in sunny N. MI
>Normally, I wouldn't shellac the outsides of drawers, just the insides. But since you've done that already, just sand it smooth and they should slide well again.
Try "French polish" technique to smooth out the brush marks.
Howard Acheson
>The first coat of any finish leaves a less than smooth surface. The finish somewhat swells the wood fibers which raise above the surface. That's the reason for sanding the surface after applying a primer or thinned first coat of finish. So, all you need to do, is to sand the surface smooth with 320 paper. Then either declare victory or put on another coat. That one should be smooth. To make drawers slide more smoothly, use some paraffin on the sliding surfaces.
You can continue with shellac for your final finish. Shellac is more than durable enough. Dewaxed shellac is actually harder than lacquer and much harder than an oil base finish. The best way to apply finish coats of shellac is by padding them on. Brushing can be problematic because the new coat "melts" or dissolves the underneath finish.
>First, your decision to use shellac was a good one. I habitually use shellac for drawers because shellac odors don't linger inside of casework like varnishes and lacquers do, and usually the thin shellac offers enough protection from dirt and finger smudges. But, I usually thin the shellac to about half the consistency of Seal Coat, which works out to about a 1# mixture. That way, it goes on very thin, with no lap marks or drips. It also dries hard in no time. From there, I sand the shellac surfaces lightly with 320-grit stearated paper and then wax them with a paste wax. (I like Clapham's myself. Ian Kirby uses white beeswax dissolved in turpentine. You can use odorless paint thinner if you can't hack the turps.)
On the outside of the case, you can certainly go over your shellac sealer coat with the lacquer or varnish of your choice. Just scuff sand the shellac first to get rid of the roughness and nibs. Iy you have some lap marks, scrape them off with a card scraper held straight (not bent with your thumbs). Let the scraper take off just the high spots, then sand the area lightly with 320 paper wrapped around a block of MDF or Homasote. Brush on another thin coat of shellac if you have any bare spots from the scraping and sanding, or else your top coat may not go on uniformly.
