>howdy folks - anyone out there have any tips for repairing table legs that have broken in two? my mother has "commissioned" me to repair an antique oak side table that has one leg broken off at the top joint (angled mortise and tenon) and the mid point. hand fitting the pieces back together gives a relatively tight fit up, but not perfect as some of the grain inside the breaks has been crushed. any tips?
>First take a chisel and cut off any badly aligned splinters, and get it to fitting as close as you can get it.
I like to use thickened epoxy. I keep colloidal silica for this, but you can thicken it with the dust from a belt-sander.
If the break is diagonal to the face, and it usually is, just clamping will make the parts slip out of alignment, so you will either need to put a couple of brads through the break, and just use light clamp pressure to hole the parts together while the epoxy cures. Epoxy doesn't need a lot of clamp pressure like most other glue.
If you do a good job of blending color of the fillers, it will just look like a streak in the wood-grain.
One last tip. The thinner to clean up epoxy is lacquer thinner, which will ruin almost any finish, so it is best not to get any on the face, unless you will be refinishing the piece. I use masking tape cut back from the edge just a little, and clean off the major squeeze-out with a putty knife or wedge, but leave a little bit of a bulging line when I reach the final clamp pressure. I peal the tape off while the glue is still wet, but trim that final bulging line off with a chisel after the epoxy reaches the leather hardness of cure.
>For the midpoint break have you considered boring hole in each end and using a dowel to span the joint? A similar operation would be to cut a 1/4" (or wider) groove on backside of the leg, maybe halfway through and glueing a spline. I think you have to plan for something like this to reinforce the leg against lateral forces. On the M&T break you didn't say whether the break was in the tenon or mortise cheek. You can replace a broken tenon by cutting flush and making a loose tenon to replace. The mortise cheek can also be replaced useing a router to cut a wide groove across the width of the leg and glueing a new piece of wood in. Epoxy could be used for both of these because of the gap filling properties, and they would be considered permanent repairs. The tenon should be put back with yellow or hide glue to give the next generation a shot at repairing.
