Anybody familiar with Extira?
Ray Thompson - Middletown,IN
>It is an exterior grade MDF type of material. "Moisture resistant exterior panel product for paint grade applications". I just got a small sample (5x5) to look at. It is phenolic bonded and is manufactured to a tolerance of +/- .005. I have no idea as to price or availability, need to do some more searching. My first thought is that it might make a decent substrate material.
Ray
Re: Anybody familiar with Extira?
Oops, forgot sizes
>It comes in 4' x 8', 4' x 16', and 2' x 16' sheets in thicknesses of 1/2", 5/8", 3/4", 1", and 1 1/4".
Ray
It looks like...
Lee Schierer - McKean, PA
>It appears to be almost the same as the composite decking materials (Trex, Veranda, etc) only in sheets. It does say it is not for structural use. Moisture resistance indictes that it does absorb some moisture (it contains wood) so some dimensional changes will still occur over time
Mark Nowicki
>A 3/4" 4 X 8 sheet costs CDN$62.40. Montreal is a retail desert, so if it available here it must be available anywhere. It was suggested to me as an alternative to MDO plywood.
Mark
In appearance up close.
>It is a cross between hardboard (not tempered) and MDF. Much more paper or wood looking than Trex. It is very smooth on one side and has a very slight texture on the other.
Ray
A bit salty for casual use perhaps.
Mike Schwing from Md.
>My brother just had some garage door repair done with the stuff. It looked suspect to me. I just couldn't wrap my head around it for exterior applications.
I use it...
Brian in Sandusky, OH
>...as a substrate for marquetry.
Basically there is two water-resistant MDFs.
Xtira and Medex. They are basically the same products, but different marketing.
It's essentially identical to MDF in working and structural properties, but it has a water resistant component.
I have no idea as to how it would hold up in an outdoor application, as I only use it with indoor fine furniture.
Paul Schurch taught me to use it for marquetry, and I have done so ever since.
Re: I use it...
Mark Nowicki
>It comes with a "limited" five year warranty, so it will probably last six months. Basically, it is garbage mixed with glue, I think I will pass.
Mark
fred in ct
>a 4'x8' x 1-1/4" cost $115.
Jason Roehl in Lafayette, IN
Somehow, Ray,....
>...I can't see you carrying around a 4'x16'x1.25" sheet of the stuff if it is anything close in weight to a sheet of MDF. That would be a 3-4 man job!!
I bet signmakers use it. And, I'm sure it's like most exterior-grade manufactured wood products--they have enough moisture resistance for you to get them installed and then prepped and painted.
Jason
At 48lbs/cu.ft.
>I ain't moving it anyplace. ;-)
Ray
That is where I see it.
>I figured the water resistance might give it a bit of oomph over MDF.
Ray
substrate that is.
