A55 Smoothing Plane
Help with Hinges Please
Steve Yakoban
>OK... I'm still working on my little cabinet for my wife and now need to understand mounting a door.
I understand overlay hinges to mean that the door's entire thickness sits "outside" the cabinet. So, am I right to believe that if I use overlay hinges, the door can be any reasonable thickness and the door can overlay (be larger than)the face frame opening any amount (1/2", 1", 2", etc.) so long as there's room to screw the hinge to the face?
And...
I understand that partial inset hinges means there needs to be a rabbet around the door perimeter on the back, based on the hinge details like "3/8" inset with a 3/8" lip" means an actual sized rabbet of 3/8" x 3/8". If I'm right, my question with this is: How much clearance between the frame and the inset portion of the door? It seems most hinges have leafs 1/16" thick, so should the inset portion of the door be narrower by 1/8" (1/16" each side) or more? 1/8" seems tight and what clearance in height?
Thank you very much for your help!
Re: Help with Hinges Please
>IMO, 1/8" of clearance in the height portion is usually plenty (assuming the door is square (DAMHIKT).
You may have problems with an 1/8" clearance on the sides. If you do a panel door with 2-3" rails and stiles, the wood movement may cause the door to "stick" in times of high temperature and humidity. Of course if you are using wood that is quarter sawn, it won't be as much of a problem.
Kneale Brownson in sunny N. MI
>If your overlay projects too far beyond the door opening, you may have trouble with its hinge edge hitting the cabinet when opening the door.
If you do the partial inset, you need enough clearance for the door to swing and accommodate wood swelling. Generally, you'd have a 3/8 inch masking of the door opening all the way around. I try to fit and mount doors like that using half that lip width for clearance.
Bart Goldberg
Bart Goldberg
>TO add to what the other posters have already stated, your hinge of preference should come with instructions that address the clearance issue.
Bart
Steve Yakoban
>Thanks everyone! I still need help though...
Rails and stiles are 2-1/2" wide x 3/4" thick. I favor making the door inset to use hinges 3/8" inset with a 3/8" lip. I looked at hinges at the box stores for understanding but will buy better stuff from a real supplier. However, I have to keep building before I get the hinges, so I have to make a decision now and build the door based on what I decide, w/o the hinges in my possession. A little scary, but I'm in a corner now.
I wanted to make the door 3/8" larger than the opening on all four sides.I picked up a 3/8" x 3/8" rabbet router bit and a 3/8" x 1/2". If I trim 3/8" all around the door, the inset won't fit because of the hinge thickness and would be too tight anyway. If I trim with the 1/2", the hinge won't fit. So how is that done? Is the hinge side rabbeted differently from the others?
