New 30amp service line question please
Mike Schwing from Md.
>(dupe posted on the turning board by accident)
I have wired up many 15 and 20 amp circuits on my own. Even added a sub panel for a 30 amp circuit in my old home without killing anyone. Trying to do that again in my garage so I can run my tablesaw which requires 220v/30a service. Wanted to run this by you to make sure I have it right.
The distance is not long, maybe 75 feet total and there will be only a single receptacle on this circuit. I ran 12/3 wire. I purchased a double pole 30 amp breaker. The ground and the white neutral wire both go into the neutral/ground bus bar in the panel. The black and red each go to one of the poles on the breaker.
The tablesaw has a 3 wire cord running out of it, white/black/green.
The receptacle is a 3 prong type. The bare ground gets wired to the metal box. The white neutral goes to the ground terminal in the receptacle. Red and black each go to one of the other prongs as they are hots.
From the tablesaw; black and white are both hot and go to the hot terminals matching the receptacle. Green goes to the ground prong.
I'm no pro at this - you won't hurt my feelings by telling me I have something wrong, and you may save my life! I think if anything I have backwards are the neutral and ground, as I think 30a doesn't need the neutral, but you tell me, please. Thank you.
Re: New 30amp service line question please
I've been straightened out on the ground/neutral
>On the other side..
Neutral is not needed. Wire nut it at both ends. Got it, thanks.
First place to start…
Rod Peterson -- Ormond Beach
>…is to pull that 30A breaker and replace it with a 20A. Or replace the 12 ga wire with 10 ga. Failure to do one of those is a code violation.
Next, ignoring the incorrect wire size for the moment, what you did at the panel sounds correct. What you did at the receptacle does not. Do not connect the neutral (white) wire to anything. It's the ground wire that goes to the ground terminal on the receptacle (as well as “wired to the metal box”).
There is no neutral necessary (or place to connect it) in a 240V circuit for saws, jointers, planers, etc. The same is not true for ranges and dryers, but we're not talking about them.
Rod
Thanks!
>I've got it. I'll repull with 10/2 and use the 12/3 for 110 service. I also now understand that the neutral/ground sit. Thanks!
Howard Norman-Prescott, AZ
>The key item is that the 220 volts doesn't need the neutral. You only need the neutral to turn either one of the hot leads into 110. Since the saw apparently doesn't have any 110 v requirements therefore no need for the neutral.
Howard
Dan Manturi
>You got the right info already. A Unisaw has a 22v, 15 amp plug on it. I have mine running off a 20 amp breaker using 12 gauge wire. You have a hot, hot, ground situation, as stated the neutral is not used. I just survived this learning curve with help from this site. I ran a load center off my main panel using 6/3 wire off a 50 amp breaker so i have all my breakers handy in the garage (plus I have 2 - 220V devices). Also added a couple more 120V - 20 amp lines.
Good luck and be careful.
Dan M.
Before you spend more money...
Rick Christopherson
>You indicated that you ran a 30-amp circuit for your tablesaw, but only used 12 gauge wire. However, before you go out and buy the 10 gauge wire, are you sure that you needed a 30-amp circuit? Unless you have a 5-hp tablesaw, you don't need the 30-amp circuit. A 3 hp tablesaw will run (and be within NEC requirements) from a 20-amp circuit with 12 gauge wire.
The reason I am asking is because this information gets so confusing on these forums that many people believe that they need 30 amps when they don't. It also doesn't help that the Grizzly instruction manuals are notorious for misstating this information.
All done, works fine now, thanks much!
Mik eSchwing from Maryland
>Thanks guys. Took the advice, and sure enough it works just great.
Re: Before you spend more money...
>Thanks Rick. It is a 5hp Jet cabinet saw.
All done now, works as it should, and I have no further concerns about the wire (10/2). The previous run will be used for 15 amp service.
