Another wall mostly done...
>That's two walls mostly done. Still need to build a sharpening station cabinet to go on the right side of the lathe.
I've got a weird idea for the "counter top" for that cabinet. A while back, I had to build a "white board". I have some left over shower liner board from that project. I've been making "sacrificial" counter tops of tempered 1/4" hardboard over 3/4" plywood and holding the hardboard in place with strips of oak scrap that are 1 1/4" x 3/4" x whatever long. I'm just using the close fit to keep the hardboard in place and to keep the counter top assembly on the base cabinet.
What I propose to do is use the leftover shower liner board in place of the tempered hardboard. I may (or may not) grout the sides of the liner board. I figure that way, the water from the water stones or the Tormek won't hurt anything.
Re: Another wall mostly done...
Pete in Holland, MI
>Wonder if you otta place a piece of wire fencing or Lexan between the lathe and your window? Might save a broken glass and all the hassle that comes along with that. Lathes have a tendancy to excite thing to gain high velocities without notice.
Re: Polycarbonate sheet is on order.
