Fun with box joints
Fun with box joints
Fun with box joints
Steve Kreitler
>In my continuing quest to make the simple look complex (and have fun with my single-point box joint jig), I came up with this- It's simply a box joint, but before cutting it I rabbetted the ends of the oak pieces and glued on some black walnut with the same grain orientation. Kept the rabbet short so that the walnut wouldn't show on the inside. The 45 degree chamfer on the edge serves to further confuse the eye, blending everything together. This pic is pre-finish, btw- just a light stain on it. I like the way this came out, and think I'll be doing some more like it.
Re: Fun with box joints
Bart Goldberg
Bart Goldberg
>Steve,
Nice work. I like making boxes myself. Mind if I ask, what is your single-point box joint jig?
Thanks
Bart
Don Pierson
>I like your box. As a newbie hobbyist a small box is as big of a project that I will attempt. Last week I finished a bank for my granddaught that is similar to yours. I didn't do any fancy joints because I was pressed for time. Fooling with the postal door was fun. I cropped and printed out an image of her eyes and nose and put in the window.
Re: Fun with box joints *LINK*
Steve Kreitler
>Here's the one I use (link below)- it's not *quite* as easy to set up as they claim, but then I am a bit of a perfectionist. It works quite well, and is easy to use. It is essential to make sure that your router isn't moving in the table- when I first used it, there was a bit of play in my insert, which made it very frustrating to try to use. It's been easy going once I got that sorted out, though.
Oh, and they sell this one at woodworking shows- that's where I got mine, and you can probably get a better deal there. Try www.thewoodworkingshows.com to find one near you :)
woodline spacer fence system
I like the face in the window! NM
Steve Kreitler
