OT - Plumbing whistle
Ken Miller
>My plumbing makes a whistling sound whenever a toilet is flushed, outside faucet turned on, doing laudry or basically anytime other than just the faucet to say wash your hands. I can't pinpoint where the sound comes from since it only does it for about 3 seconds (not the entire time that the water is running and it happens no matter on which floor the water is being used). Is this a sign that a pipe is going to give way? How worried should I be? The house is a '91.
Re: OT - Plumbing whistle
Keith Newton
>I think this is usually a trait of some sort of constriction. The house doesn't seem old enough to have lines that are getting plugged up from minerals or rust, so I would first check to make sure that there isn't a shut-off valve somewhere that is only partially open.
If this is not the case, I would bet that you are not in a house on a slab with the plumbing under the slab. If there is a crawl space, you need to get under there while having someone above making the sound happen. You should be able to sound it better down there. Feel of the pipes with your hand. You will probably find that you can kill the vibration with a wedge or something jammed in a hole where the pipe is loose somewhere and setting up a harmonic vibration.
Also check the lines going into and out of the Hot-water-heater. Make sure they are open all of the way also.
Saw this on "Ask This Old House"
Jim Rahbe, Bedford, TX
>Ken,
Seems like �Ask This Old House� had an episode about this same subject. Turned out to be a toilet valve. Apparently when the water is turned on, there is some type of pressure change that makes the toilet valve whistle. You could temporarily turn off all the toilets and then check to see if the noise still happens.
Jim R.
Re: agree
Grant Smith(remove 1 for email)
>Suggest you close your toilet valve halfway and try the flushing again. You should then be able to fine tune the valve setting so you get rid of the whistle while still getting adequate flow to fill the toilet tank.
Also make sure you check the valve for leaks once you find the best setting. They tend to leak when messed with.
Dale Lenz
Re: OT - Plumbing whistle *LINK*
Dale Lenz
>Check out the link below.
Good luck and let us know how you solved the noise.
Pipes that want to be singers
RK in Milwaukee
>This was on Ask This Old House but I couldn't find it on their website. The whistle sound is caused by a drop in water pressure in your pipes. There is a pressure regulator inside the flushing mechanism that needs to be changed. That's as much as I can remember. Try contacting the manufacturer for more specific info. Hope this helps.
Ron Nelson
Some valves
>It's been my experience that some cutoff valves will leak if they are turned half way. They must be either fully open or fully closed otherwise they leak.
Happy Woodworking!
