Levelling a heavy workbench?
pecker
>I plan to build a fairly substantial woodworking bench, in the 150 to 200 pound range. Unfortunately my crummy basement workshop floor is neither flat or level. All my equipment has shims here and there to keep it from rocking, but for a bench I think it will require something beefier to insure the bench doesnt move around when planing, etc. In all the plans I've seen for benches, this is never addressed. I don't think the typical furniture type levellers, with their 1/4-20 studs are gonna cut it.
Any ideas?
Re: Levelling a heavy workbench?
large T-nuts and bolts
Dave Bair, Eaton Rapids, MI
>It'll require some stooping and bending to get an open-end wrench onto the bolt for adjustments, but my 200#+ bench hasn't moved in 3 years. I used 3/8" t-nuts and 2" long bolts. Best drill the holes and insert the nuts and bolts before assembly. I didn't, and flipping it over and back was just barely doable without help. In my defense, I planned to use shims, but the unit kept sliding around under heavy use.
Dan Donaldson
>Someone here did some levelers using old hockey pucks. You might be able to find it with a search of the archives.
>Go to Enco www.use-enco.com and look up machine levelers. They have a pretty good variety. I put some with a 3/8" bolt under my Powermatic lathe. It weights 1000 lbs with the stone ballast.
My thoguhts exactly
Lee Schierer - McKean, PA
>T-nuts are cheap and easy to install. You can also use a 3/8 carriage bolt instead of a 3/8 hex head bolt. Install a thin lock nut on the bolts if you think they need locked once the bench is leveled.
Lee
Some pictures of what I did *pics*
GolfSteve in Calgary
>Actually I wouldn't worry about standard appliance levellers (except for the really crappy plastic one's which were included with my tres expensive washing machine...but that's another story).
The appliance levellers I bought were rated for something like 150 lbs each...so assuming equal load distribution and four legs, that's 600 lbs. There's probably a safety factor on the 150 lb rating, so I wasn't worried.
Here's what I did so that the foot was both adjustable from the top and "low profile" - ie. not visible as a foot below the bench. I didn't want the foot to be very visible. By no means is this my idea...I think the Michael Fortune bench has something similar in that book.
Here's a shot of the underside of the foot. I drilled several recesses so that the nut and foot could be retracted fully flush:
And a shot of the underside with the nut installed from the bottom side:
A shot of the foot installed from the bottom side:
A shot of the foot from the side before I profiled the foot end. You can see that the top of the screw sticks up above the leg. I later cut that off flush with the top of the foot profile and used a hacksaw to cut a slot in the top of the bolt. That way I could adjust the bolt from above using a flat screwdriver. This works like a charm.
And a shot of the finished product:
One caveat
>One caveat...my bench is pretty heavy. I would guess around 350 to 400 lbs. It does not slide around at all.
However a lighter bench and/or a painted concrete floor combined with the teflon pads on the levellers I used might allow the bench to move around a bit....? Nothing that a piece of rubber under the leveller wouldn't fix.
And as far as other bench plans not addressing this...take a good close look at pictures in The Workbench Book (and other books). Others have addressed this problem...by using wedges, shims, or other doo-dads stuck under or bolted to the legs to keep them levelled and stationary. I think there's even a picture of Garret Hack's bench (or perhaps it was Brian Boggs?) with a bunch of cedar shims hammered under the legs.
Bombproof Levellers
Hank Knight
>I overengineer everything. My workbench levellers were no exception.
I ordered 4 heave machine levellers from MSC Industrial Supply (www.mscdirect.com). They have a 3" swivelling non-skid pad with 6" X 1/2 X 13 studs and each supports 1,000 lbs. I had my local machine shop make 4 "leg caps" (my term) from 3" X 3" X 1 3/8" steel plate. They turned the plate on the lathe to make a 3" X 3" X 3/8" base plate with a 1 1/4" X 1" stud that fits into a 1 1/4" hole drilled into the bottom of the workbench leg. The leg caps have a 1/2 X 13 tapped hole through them for the levellers. They give me about 4" of height adjustment and are absolutely bombproof. My Bench weighs about 475 lbs and hasn't moved an inch since I fininshed it 3 years ago. Here are some pics.
Re: Bombproof Levellers - Pic #2
Hank Knight
Re: Bombproof Levellers Pic #3
Hank Knight
Re: I used these
Edward inVancouver
>I've got the same ones on my workbench too, the ones L.V. sells. A nice feature is that you can adjust them with an allen key with no obstructions of any kind. Liked them so much I installed them on my baker's tables at work too. (In my "other" life I'm a baker...)
Golf Steve has just hit on the easiest cure for...
Art Silva
>making sure a bench does not move. I have three 24 x 60 rubber mats under the bench. Any variation from level can be adjusted with hardwood shims under the legs/feet, and the bench will never move. The rubber mats save my back and knees, and if I should drop something it hits rubber.
Twenty years ago I set my Unisaw on a 30 x 30" x 1/2" thick piece of conveyor belting, and shimmed it level. It has not moved since. Good luck. Art
Different approach
David W
>I took Lon Schleining's class at Marc Adams this summer and am almost finished with my Master's Bench. Lon suggested to someone who asked about leveling to take an angle grinder to the concrete floor to accomplish the leveling.
