TS extension wing Flatness question?
>I have been installing the Biesemeyer Fence I snagged from Lowes thanks to a post here.
My saw had aluminum grid extension wings. They would not work with the Biesemeyer fence because it slides on the table. I decided to cover them with plastic laminate (Formica). I have also added an addition extension that has a router hanging in it. I decided to cover both the original grid and the homemade one with laminate at the same time to clean up the looks and eliminate the seam between them.
I filled in the gaps in the aluminum extension table with plywood and bolted it to the homemade router table. Checked them for flatness. Thought is was good. Put the laminate on and trimmed the edges. Put the assembly back on the saw. Mounted the fence. Found a bulge or slight ripple in the surface. Less than a 1/32" at the join between router table and the aluminum extension. Does not interfere with the Biesemeyer, but it ticks me off. I thought I was getting it perfect. The question is, does it matter? The practical side of me says no. It is so far out from the blade that it will not affect any precision cuts.
