Tap for 5 gal paint can?
Mark Kauder, Phenix City, AL
>I use enough lacquer these days that I buy it in 5 Gallon buckets. Do any of you know of a "tap/Faucet" that I can put on the paint bucket? So that rather than decanting (usually with a mess) the lacquer off into 1 gallon thinner cans, I can just put the lacquer right into the spray gun.
Mark
Re: Tap for 5 gal paint can?
Dale Lenz
Dale Lenz
>Mark,
I just purchase my first 5 of lacquer a week ago. I also purchase a $.79 sprout thingy that suppose to fit in the bung hole, according to the paint store, Sherwin-Williams. Have not tried the sprout thing yet, but looks promising.
Robin Corell in Atascadero, CA
>when pouring from a 5 gal container it may seem intuitive to pour with the spout closest to the side from which you are pouring, but if you pour with the spout farthest from the side you are pouring from you will make almost no mess. if you use a funnel you can actually pour from a 5 gal without spilling a drop. This same principle also works for square gallon cans with the spout in one corner.
Robin
Re: Tap for 5 gal paint can? *LINK*
Carol - now in NC Nebraska
>Try here, Mark.
spigots
Thomas S Stockton
>They also make a stand you clamp the 5 gallon can into that swivels to help eliminate spilling
Tom
My dad taught me that...
Tim Greif - West of Chicago
>Years ago when I was a teenager (translation: smartest person in the world), my dad tried to convince me that if you poured from what seemed to me like the wrong side of the can, you'd spill less and have more control over the pouring. I, of course, knew better and refused to do it his way. End result was that I always spilled. Now that I'm older and stupider (by teenager standards), I do it his way, and almost never spill.
That's just one of many things dad imparted to me as a young lad that I never appreciated. The list is long. I miss him.
Re: My dad taught me that...
>Yeah, I grew up in a auto body shop, and learned the same things, but it still doesn't help when the full falls out of the can when it is half full and the like. DAMHIKT
You can also pour out out of the "Right" side if you punch a small breather hole in the other side. Lacquer and lacquer solvents will not get enough free flow of air from the little hole when the cap is on for them to evaporate, but you will get enough air so that the liquid will not "Glug" out of the spout.
I am just looking for convienence.
Mark
Homebrew fermentation bucket..
Dan Manturi
>If you do not want to try drilling a hole and buying a spigot, go to a local home brew supply store and get a 5 gallon fermenation bucket. Spigot, lid, and even an airlock. probably more expensive than making your own, but ready to use.
USed to do a lot of home brewing.
Dan M.
Jason Roehl in Lafayette, IN
Probably not a good idea.
>While the fermentation bucket is food grade and quite durable, lacquer (and the solvents therein) might make pretty quick work of the fermentation bucket and/or some of its "spigotry". Metal would be the order of the day.
Jason
Roll it
Michael Dresdner
>For round cans, lay the can resting on its lip on a bench with the pour hole at the very top and the can at a slight backwards angle. Initially you might need a small riser block under the lip to let you remove the cap with no innitial spillage, but not after the first pour. Remove the cap and start to roll the bucket. As you roll it, the hole gets lower and feeds out liquid, glug free. I works until the can is just about empty.
RIGHT!! Probably not a good idea.
Dan Manturi
>He is talking metal cans. laquer - what was I thinking about?
Thanks for the correction. It probably would have worked really well for about 15 minutes....
Dan M.
Dale Lenz
Re: Tap for 5 gal paint can works!
Dale Lenz
>Tried the spout tonight, not a drop spilled. The orange ring is for threads on a can if available. The spout has a molded ring and pushes into the bung hole. The spout pulls back out, when finished pouring. I Googled "Allway 5 gallon pouring spout" what's on the spout, not a thing. I recall the Sherman-Williams' manager telling me they just got these spouts in. For $0.79, think I'll go pick up a few more.
Re: Roll it
>Michael,
What a great simple solution. Thanks
Mark
