Re: What kind of drill bit?
Steve Yakoban
>Thanks a lot guys. Number one issue: I did use a cordless drill. The jig came with the centering bit which is a brad point. I think I have enough extra material to replace the messed up piece, but I'm nervous... My wife has a faux painter scheduled to paint it and another piece I'm reassembling in a week!
I think I'm in a little over my head because I have 3 other issues:
1. The plywood top is designed to sit on the legs (stiles) which I was going to glue down to the top ends. Is that strong enough or should there be a better mechanical attachment?
2. The door (in blue) was originally intended to be inset, but I realized that's asking for trouble, so I want it to be a part overlay door. I know I can router a back cut on the outer edge but is that totally dependent on what hinges are used?
3. I'm planning on using 3/4" MDF for the back since I have it. Is that overkill or is it OK? I don't have any more finished plywood so would something else be more appropriate?
