Re: Plunge router
R. Lance in GR, Michigan
>I have the PC plunge base for the series 690 motors and also use it occasionally and I find it to be completely adequate for any plunge routing task that I've had to do including making mortices, cutting thru slots in jigs, making shelf pin holes, etc. Its part of the PC 690 system and takes PC guide bushings, base plates, and fences. The only problem I've found is that the motor can be hard to remove from this base if you allow the motor to bottom out on the base when you initially install it....so just keep the motor 1/2" above the base when you tighten it down and this little offset eliminates the problem of motor removal. Without question, there are many dedicated plunge routers that are better than this combination....but for occasional use, this will get the job well done.
