THE WOODRAT IS BACK!
horizontal boring machine set up
Ken Kimura
>Can anyone tell me the rotation and rpm of the Davis Wells horizontal boring machine? I just started mine for the first time. The spindle turns counter clockwise like my lathe and it spins at 4830rpm. I'm not sure if the rpm is appropriate for spinning end mill cutters. Thanks Ken
Re: horizontal boring machine set up
Link Van Cleave
>I have a lot of time on the Davis and Wells and I used to own one. Great machine. That speed is fine for end mill cutters and you can go as high as 15,000 or so. My multi-router uses of course a router and with end mills and they run fine at router speeds. I get cheap extra long 2 flute end mills. For drilling you are a little too fast as I seem to remember most of the d&w's running closer to 3,000 and even then they would burn. I would set up a step pulley or some way to run one speed for drilling and another for mortising. Do you have a chuck for it. About 8 years ago I bought the what must have been the last one in existance. Very hard to find now but makes things much easier if you can find one.
Link
Ken Kimura
>Thank you Link. That's just what I needed to know. I just ordered a Jacobs 36B 3/4 from McMaster. Kind of expensive but the threading will fit my lathe. I thought the speed was high for drilling. I'll look around for a 1,725 rpm motor. Thanks again.
