Granberg Mark III Alaskan Chain Saw Mill
Mike Baratta
>Hi,
Has anyone had experience with this unit or others like it to turn downed trees into dimensional rough cut lumber where they lie? I've recently moved to the west Philly suburbs and bought a home on a heavily wooded lot. I have a 2' dia poplar tree that is down and other trees that will be taken down over time to let more light into the house. These trees are 18-24" dia and they go staight up 50' before there is a branch. There's a lot of great wood in my future and I'm considering how I should mill it up. I saw this product and it looked like a good value at <$200. Would like your thoughts.
Thanks,
Mike
Re: Granberg Mark III Alaskan Chain Saw Mill
Steven Antonucci
I would think it would be a lot of work
steve antonucci
>milling a 50' tree with a chainsaw mill. I think you might be better off finding someone locally with a trailered bandsaw.
Steven
P.S. Milling a 50' tree is a lot of work with a bandsaw too...
matt overton
>It is a lot of work. you need a powerful saw and lots of muscle. It is good for trees under 15" dia. It would probably pay to have a portable bandsaw mill to come on site to do the cutting.
Mike Baratta
>I appreciate the pragmatic responses. I don't exactly have a lot of spare time on my hands either with five small kids (under six years). Any suggestions on finding someone with a bandsaw on a trailer? Another thing: How in the world to you move 8' long sections of an 18" diameter log? They must be unbelievably heavy.
Mike
Gary Evans Tallassee, TN
>Hi Mike,
Besides the cost of the mill, you also will have to spend several bucks on a big chainsaw to operate it. I think you'll find you'll have all the work you want just handling the lumber as it comes off the bandsawmill.
You can call Woodmizer (don't have the number in front of me, but you can get it from their website) and they will give you a list of Woodmizer owners in your area who saw for hire. I would expect other bandsawmill manufacturers to have a similar service.
To roll those sections of log around, you'll need a peavey or cant hook. You can probably get one from your local Farmer's Co-op.
If you are curious about the weight of a particular log, you can go to a calculator over on WoodWeb that will give you the weight based on the species and dimensions that you enter. They also have a bdft calculator so that you can give your sawyer a fairly accurate idea of how much volume you want to have sawed.
Remember that things go faster if you already have the logs organized so that you just have to roll them to the mill. If you have someone local with a tractor and boom pole, you can stack a bunch of logs in a fairly small space. You'll also want to get your stack foundations and stickers ready so that the lumber doesn't have to lay very long before you get it stacked up ready to dry. These hot, humid days, you can start making mold and stain in just a day or so between the faces of two boards that are touching.
Gary
Robin Corell in Atascadero, CA
>I mill most of the wood I use with an alaskan mill. Contrary to what many people think it is most efficient on large logs, and on truely large logs it may be the only option for portable milling. I prefer logs that are over 24" diameter because the the set up time for the first cut is the same regardless of the size of the log, and the time to cut per square inch is the same so it is more economical to mill larger logs. also large logs have a greater percentage of higher grade wood.
For something in the 24" diameter you need a saw that is close to 90cc and for anything biger you will best be served by a saw that is over 100cc. this will quickly take chainsaw milling out of the realm of a casual thing you might do with the firewood saw you may have on hand. most of the saws that will fit the bill for being appropriate for milling will be in the $600 price range with the biger saws going for over 1k. I should also mention that you lose 6" of bar capacity by bolting a mill to your saw ie: to mill a 24" log you will need a saw with a 30" bar.
Chain saw milling is dirty, smelly, sweaty, hard work. and I should probably underline the hard work part. it is also something I encourage woodworkers to try. Anyone interested in more info please feel free to contact me directly.
Robin Corell
Pat Mulligan
>I've done it. Listen to Robin.It is a good way to make your lumber though,I have a big stock of various woods put away.For a busy person -get the bandmill and a helper or two.
Bill Blasic
Bill Blasic
>I have one that I use with my Stihl 066. It is a lot of work, it seems to work best with larger logs, and I like to have the log point a little downhill so that gravity helps. My main use anymore is cutting 4" slabs. When I had a lot of cherry to cut a friend came over with his LT37 and sawed up about 4K. Now that was a lot of work also moving all that cherry from saw to the pile.
Kit Gage in VT
>Mike,
Go to http://www.arboristsite.com and spend some time in the Milling and Sawmill section. If that doesn't convince you, nothing will. I have a couple of chainsaw mills and, yes, it is dirty, smelly and a lot of work, but it is addictive. Making something from a tree that you cut down and sawed into lumber is priceless!
More of the same...
Ken Platt (North Granby, CT)
>I tried using one of Granberg devices with my Stihl farm boss saw. It's a reasonably powerful saw for regular usage, but milling even the small logs I could do (I used a 20" bar and a rip chain) was exactly as others have described: hard, slow, dirty work.
I found a local guy with a woodmizer, and with that, milling logs became a thing of joy. If I had one of those, my 6 acres would probably get clear-cut. It is just serious fun.
I am very much the sort of person who will tackle just about any job rather than paying someone else to do it, but for this one, the woodmizer is the way to go IMO.
Ken
JKJ in East TN
>One thing to consider: compared to a bandmill, a chainsaw mill wastes a large percentage of the wood, especially when cutting 1" stock.
I researched this topic in great depth a few years ago after buying a farm with a lot of trees and several old buildings that needed work. The most attractive things about a chainsaw mill are dirt-cheap price, the ability to mill where the log lays, and the potential to cut slabs from large logs.
You might also want to check out the portable bandsaw mills that work very much like the chainsaw mills. For example, the Ripsaw (http://www.ripsaw.com/) uses a chainsaw engine, can be carried to the log, and has the advantage of the thin bandsaw kerf. However, the maximum size of log is limited compared to a chainsaw mill. (Note that working large logs with a chain mill requires a fair amount of power.)
I ended up buying a Woodmizer LT-15 bandmill (not portable or transportable), but it was a toss up whether to purchase a mill or hire someone with a portable mill as needed. Besides the expense of the mill, it needs a dedicated space and some heavy equipment to muscle logs around. I did find out that once you have a sawmill there is no shortage of free logs - I have a huge backlog at the moment and would be drowning in logs if I didn't know how to say no!
Note that if you do decide to have someone mill the logs for you and if you need to accumulate a number of logs to make it worth while, you can keep most for quite a while with limited degrade if the endgrain is coated and the logs are kept off the ground. Better yet, remove the bark to minimize insect damage. I've cut some great boards from logs several years old.
Another thing - if you have any REALLY large logs, find a sawyer with a swing mill. This is a transportable circular sawmill that is set up around the log where it lays and is especially good at milling dimensional lumber (2 bys, etc).
Stephen Kirk in Quakertown PA
>I had thought about a chain saw mill a while back, and I took the advice here from many to not try unless I wanted to make an investment in a big chainsaw (1000cc saw is a heavy, loud beast). Also, I started comparing prices of new/used small bandsaw mills. The entry level Woodmizer (no hydraulics) starts at about 6k. Some hunting can turn up bigger used band saw mills for around the same price. I started wondering ... over a thousand for a high end chainsaw, 200-300$ for the alaskan mill, several chains and sharpening equipment, and a lot of physical labor. By the time you are done, you paid about 1/3 of the cost of a band saw mill. The small band saw mills even disassemble and fold up for storage.
Lately, a friend of mine has started an independent forestry business and would like me to go in with him on a mill. We'll have access to lots of trees. It'll make money for him, save money for me. My future might have a band saw mill in it.
As for finding people, I e-mailed Woodmizer, sent them my zipcode and they sent me a list of woodmizer owners in the area. Also, check WoodWeb, there is a locater on there. I'm probably only an hour or so north of you and I know we have mill operators around. If you can get a lot of logs ready to go at once, it'll be cheaper since many operators will charge mileage to and from the site. Some want at least 4 hours of work, etc. Depends on the operator. Some operaters will give you a better deal if you bring the logs to them -maybe contact a tree service about transportation.
Hope something in there helps. Woodfinder right up top of this page can locate sawers too.
Rob Stokes in North Vancouver
>I'm putting the final touches on an Alaskan mill now. I've bought a used Husky 2101XP (99 c.c., 6.7 hp) that was originally a commercial fallers saw (full wrap handle). It's not pretty, but it's all there. I've replaced the clutch, sprocket (and seals) on it. The saw's got a 37" bar it's been converted from a .404 to a .375 and it's loaded up with a brand new ripping chain. And I've I've got a "long term loan" on a 36" mill but these can be had for $100 if you look hard.
Total investment? I'll be under $500.
Yup - milling wood this way is hard work. But it's one of the most satisfying things you can do. And at the end of the day, while I'd like a band mill, I can park "my mill" in the shed and not feel guilty if it sits there for a while.
Rob
