Delta DC-380 planer stripped gears
Paul Pestock
>I have a 5 year old planer that has received fairly light use.
The feed rollers suddenly quit on me. After disassembling the gear box, I found the middle pinion stripped on the small, inner teeth. The teeth that allow it to turn at the slower feed rate. Plenty of gear oil in the box. Everything else is tight. Bearings are all good. Has anyone out there experienced this? I ordered the parts on line, but I'm at a loss to figure this one out. Thanks for any insight on this.
Re: Delta DC-380 planer stripped gears
Don Evans
>Paul:
First let me state that I'm not familiar with that particular planer. However, a gear train is a gear train (or transmission) whichever you prefer.
Something could have jammed momentarily and stripped the gear, there are lots of things that may have caused the trouble. Also gears wear and as the teeth become shorter or worn it takes less resistance to stripe them off.
One thing you should check is to see if they built in adjustments for the gears, how they mesh. When you replace them with the new one's make sure, if they are adjustable, that the teeth engage fully but DO NOT BOTTOM OUT. You need to start with the first gears and follow through the whole box in order making sure each is correct. Also wear on a shaft that the gear rides on can cause this same trouble. Compare the old gear on shaft with the new one to determine if there is a difference, or sloppy, as the shaft may need replacing.
Good luck.
Don
Chuck W
>Or maybe a bearing has failed allowing the shaft to drop in relation to the other gears.
