Re: Router Table/Lift Questions
John Ballance
>I have a Woodpecker PRL mounted in the right extension table, with a PC 7518 router mounted in. This setup allows above table height adjustment, and above table bit changing (using offset wrenches). I've built a dust-collecting box around the router, tied to a dust port on the back. I added a Rockler router switch under the rip fence rail, so I can turn the router on and off without crawling on my knees. I brought power to a set of plugs mounted under the back of the table saw. The router switch and mobile dust collector plug in there, along with the table saw. This works since I never operate the table saw and router at the same.
I use an Incra Twin-Linear fence mounted to the right end of the extension table, so I can get it completely out of the way if needed to use the full table saw extension. I could also use the table saw fence for a router fence in a pinch. The entire setup works great, and I find that I use the router table far more often than a hand-held router because it's always available.
Is a lift essential? -- not really -- but it sure is convenient.
Good luck.
