Question on 4 way clamp
Larry Clinton At Frankfort (Central)., Indiana
>i have a pretty good assortment of clamps Bessy's, pipe clamps, U clamps, and a bunch of cheap bar clamps. I have been using the bessy's to assembly panels, with cauls for alignment. I have purchased some items from HF with decent results ( most of their items I wouldn't buy). I received an Email ad today with a "4 way quick action clamp. Wondered it these are worth buying. I am planning to help my son build all his kitchen cabinets. We will be using cherry with solid panels. The 4 way clamps - if they work as advertised might make panel glue up easier. Anyone got these - if so are they worth buying? Appreciate any info.
Re: Question on 4 way clamp
Rick L
Re: Absolutely not... *LINK*
Rick L
>Curved cauls with standard quick clamps and panel or pipe clamps are the best you can get for the money. Those clamps will not work as well and you are better spending the money on more quick clamps and pipe clamps. Quick clamps are better than the Bessey's as you have more room to tighten. Personally I don't care for the bessey style clamps. I can glue up 4' x 8' panels with curved cauls by myself with perfect registration. I always finish thickness my boards before the glue up because all I have to do is scrape off the glue and sand out the planer marks.
quick clamp
Re: Question on 4 way clamp *LINK*
>Larry,
I have not used those particular clamps but I used curved cauls on the 50 or so panels in my kitchen, as Rick mentioned above. They worked well. You would need to put a curve on the cauls using the clamps you mention above anyway. The cauls tend to bow up in the center if you do not. I used a combination of clamps, similar to the ones he pointed to as well as come QuickGrip clamps.
I also found that clamping the curved cauls at the ends of the cauls, past the edge of the boards increased the tendency of the cauls to bow up in the center. I find it is better to clamp the ends of the cauls over the ends of the panel boards.
The most important thing in making the panels is to properly joint and fit the panels before glue-up. That takes much more time, from my experience, than the glue-up. Of course, I did not have a wide jointer at the time so I hand planed most of the faces flat.
You really need to get the faces flat as well as the edges jointed before glue-up to get a good, flat panel. Springing the edge joints a bit is also a good idea.
My Kitchen
Those clamps are great for work holding
Forrest Addy
>Those clamps are great for work holding but because their grip is so shallow it provides assymetrical clamping force for all but thin glue ups, not rail and stile panel doors. The rails and stile are almost sure to droop towards the clamped edge. Cauls and pipe clamps are the surest way to flat finished panels no matter what Norm uses in New Yankee Workshop.
By all means use those clever clamps for gripping work for machine and bench operations but never for gluing flatwork.
R. Lance in GR, Michigan
>I have some of these type clamps from Rockler. I find that they are not made particularly heavy duty and that they are not a means of attaining production-level panel output. However, I've had good results at producing flat panels with these clamps. As stated, you must spend time getting your stock flat and square edged prior to the glue up to be successful and I've found that you really have to be watchful with Besseys (which I love) or other traditional clamps because they can cause a panel glue up to bend or curve even when those stock edges are dead flat square. By placing a 4-way every 18" or so on a panel and by gluing 2 to 3 boards at a time and then adding another board or two after the initial group takes a set, I'm able to get through the process with my sanity intact. You will have to make the wood cauls/glue boards for these clamps. I used 3/4" bb plywood by gluing two pieces back to back and then cut slots with a dado to accept the clamps instead of using the plastic strips that come with them. I also placed plastic laminate on the edge that goes against the glue up to make removal of glue squeeze out easy from the wood cauls. So on the tool vs. toy continuum, I'd rate these clamps as a tool ....but just in the tool catagory....just.
Re: Thanks - Guess I'll pass
>on the clamps. I'm not having any problem producing flat panels. Just finished 16 of various sizes. I do have a 20" planer with Byrd head so usually make the panels extra thick and send them through the planer. I just thought the 4 way clamps might be an easier quicker method of clamping up the panels. Sounds like they are more of a gimmick that doesn't do what they say. Appreciate the answers - even at $15 ~ $16 each, I would have spent $60 - $70 for something that don't work well.
