ebony
ebony
ebony
Joshua
>Hello, I'm new to woodworking, actually the only experience I've had is wood shop in high school. I'm currently working on a project where I'm making a cane out of ebony, more then likely not a good wood to start with. Well I've got the shape turned out on my friend's lathe, but now I'm not sure how to finish it. I want to keep the deep black color, but I'm afraid sanding and other methods will change that somehow. If anyone has any ideas here please E-mail me at blssdb3@yahoo.com, or post on the board here and I'll come back and check. I would be indebted for any help you might be able to give. Thanks, Josh C.
Re: ebony
Re: ebony
Joshua
Re: ebony
should be ok...
John in New Mexico
>The finer you sand, the nicer it'll look! Maybe buff with steel wool or scotchbrite, then finish with a coat or two of a thin penetrating oil (or a film finish, your call, but oil is easier, IMHO) and it should stay nice and black. Try it on a scrap if you have one, I think you'll like the results.
John
Re: ebony
Re: ebony
>Ebony wood is black all the way through ;) Depending on the type of ebony it will have some color variation in the wood. I have made several ebony pens and for those I usually sand them on the lathe to a very fine grit using silicon carbide sandpaper. This is available at most auto parts stores and you could also buy it online I'm sure. It comes in very fine grits, and I usually start at about 220 grit after smoothing things out if necessary with coarser and less expensive sandpaper, then go 320, 400, 600, and 1000 grits. Most of these exotic woods are naturally oily and the wood takes a very high polish. After polishing I would apply an oil finish as noted in the prior post or possibly no finish at all. Ebony is a naturally rot resistant and very tough wood so it would not really be necessary to apply finish.
Re: ebony
Re: ebony
mike mcnerney
>sand to 220 & apply a wipe on poly maybe just 2 coats, buff with ultra fine steel wool. If you get too much finish it looks like black plastic & you won't even be able to tell it's wood. Oil always looks great at first but has to be replenished eventually.
Mike McNerney ottawa
Re: ebony
Re: ebony
Paul Woolson
>I work with ebony on an almost daily basis (guitars). It's got its quirks but it can be amazing wood.
What you were seeing as "greying" was likely the contamination from the sandpaper. If it's Gaboon Ebony, it will be jet black through and through. Of course there are many, many ebonies out there, including some that are native to the U.S.
As said before, sand it to a high grit. 2000 would be my choice. And if you have access to Micro Mesh take it all the way up to 12,000. Then wipe on some oil. Tung oil or true oil would be a good choice. I use linseed oil as it never really dries (good for fingerboard treatment)
If I were you, I'd stay away from any water borne material. It can give a blue cast to ebony.
Re: ebony
Re: ebony
Jim Shaver - Oakville, Ontario
>Hi,
I have been working ebony all this week.
I sand 320-400-600, then power buff at 500 rpm with tripoli and then white diamond, I get a really glossy natural finish this way.
take care,
Jim
