bending cedar siding advice/thoughts?
mkula
>Ok, I bought a 100 yr old victorian home with a rounded/curved sort of turret on the front facade. Looks great, but as with all old homes, needs continual work. One issue is the bottom 5 or so runs of the 4 inch bevelled siding deteriorated and came off the rounded part (was removed somewhere along the line), and now I get to figure out how to replace it. I know back-in-the-day they used to steam it and affix it that way, but A) I lack any sort of steamer and B) no one does that work professionally around here anymore (besides, even if they did, I am too cheap not to try some fix myself).
So, anyone have experience with this? advice? MUCH appreciated.
Re: bending cedar siding advice/thoughts?
>What's the radius of the bend? What is the profile of the siding? I'm thinking you could just bend it if the radius is fairly large and the siding thin. It would help if the siding were very straight grained also, I think. Try finding some that is "clear, all heart, vertical grain." Fastening the ends would be the hardest part. Maybe you could arrange for them to fall under a trim part and really fasten it well.
Joseph Mulherin
>I once read an article where you use a Downey fabric softener. You setup a trough say 6-8 ft long, fill it with heated water, pour in a couple cups of Downey and let it sit for a day. Seems that the grains will soften and allow some bending of the wood....and when they dry there is no bad affect for staining, painting, or whatever. Do a search on Google to see if there is this article available.
woodenleg
>Look for a custom wood miller. The guy that has his mill just down the road from me makes his living cutting wood for projects like yours. He has good wood and most of the time is cheaper then regular wood stores. Dave
Ron Hildreth, Alta, Iowa
>Mkula,
As Barry suggests, try bending the siding around the radius, but if that doesn't work and wants to break, the only way I can think of that might work would be to turn each piece of siding face down and cut relief cuts perpendicular to the length of the siding on the back side. Not sure how thick your siding is, but start with shallow cuts, about two or three inches apart. Both depth of cut and distance apart will be experimental until you arrive at what works for the radius. Word of caution- after making the relief cuts and before nailing it in place permanently, heavily primer the back side of each piece, and caulk any cracks and joints well after you nail in place. This will lengthen the life of the siding considerably!!
Hope this helps!
Ron in Iowa
Jim in Burlington Ont.
Couple questions
>Is it flared from the top to the bottom? Are the singles in a scalloped pattern? If the answer's are you your in for one big job. The couple that I looked at had tapered shingles. There was also a lot of water damage on the structure itself. Each shingle has to be sized in a slight trapezoid then put into boiling water. See if you can buy up some cheap scaffolding. There's even a nack to nailing it down properly to get very few splits. I'd certainly put ice and water shield on after the rebuild. I'd call This Old House and see if you can get Tom Silva over to help out. Sounds like a fun project I'd like to see a pic.
Re: bending cedar-- more info
mkula
>Thanks for all the responses and ideas. And some good questions raised. First, fortunately it is just the lowest 20 inches or so off the porch that need to be replaced (I suspect it's gone because the doope who rebuilt the porch deck there did it incorrectly and the rain off the top of the witches-hat roof cascaded down, then bounced up under the bottom rows of siding and rotten them out, my hunch, but that's the easier fix actually).
And as for the radius-- I have to measure to check but we've been slammed with rain all day, heck all week, and haven't gotten out there. Anyway, it is actually linear siding, not shingles-- 4 inch X 1 inch a thickest point, with a bevel-- 3+ inch exposure. I fortunately had a good local place that sells it in stock, straight grained clear cedar, and I bought one bundle to experiment with. I tried just forcing the issue and just bending it myself-- some 6 foot lengths, and it just barely can make the turn... barely but not fully to give me tight seams, etc.....and so I was figuring some sort of help, like steaming, would give me just enough extra play to do it well.
I'll check into the fabric softener, and yeah, I have thought of trying Tom Silva and Ask This Old House as well. I have plenty of other issues they could help with too!
If any of this helps with more ideas, feel free to keep em coming. And again, thanks for the great stuff here already. Mike
DB
>All the equipment you need to do steam bending is a heat source, water container, and steam box with some sort of hose to connect the water container to the box.
The heat source can be as simple as a camp stove. The steam box can be a length of plastic pipe (abs or pvc will work) 6" to 8" will be good for your purposes. The hose can be anything that will handle the heat like flixible metal ducting used for dryer hookups. For the water conainer you will need to get creative in how you hook the hose up to the container.
I suggest that you obtain a book on steam bending. Try the library or book store.
I Agree
Mike Fitterling
>Steam bending is not all that complicated. Tage Frid Teaches Woodworking, Book Two has a section on doing it that you may find useful.
