Informal Survey: how many straight bits have you?
Bill Hylton
>It's just something I'm curious about.
How many straight router bits do you have? And what are they? Spirals as well as conventional straights.
How about pattern and flush-trim bits? What do you have in that category?
And finally, mortising bits (as in hinge mortising) and dado cleanout bits?
Thanks,
Bill
Re: Informal Survey: how many straight bits have you?
Denis Ch�nard, Orl�ans, Ont.
>Approximation here...
About 15 straight bits, from 1/16" to 1" in diameter
Three spiral (upcut) ones, 1/4, 5/16 and 3/8"
Maybe 8 pattern and flush cut bits, going from 1/4 to 3/4" diameter
No mortising or dado cleanout bits, though.
DC
Nick Tuzzolino
>Including all you mentioned (too lazy to categorize) a quick count gave me 39. I can't believe it!!
Maybe a hundred. Several asortments. Most 1/2"
Forrest Addy
Al Stokka - Cambridge, Iowa
>Only one. �" diameter pattern bit.
Al
Scott Greaves in Blackfoot Idaho
>Hi Bill,
Three straight bits. Two flush cutting bits. I know, I know - I will go and buy more tools immediately! (I'm so ashamed!) ;-)
Scott.
>Good Afternoon Bill,
I just counted 16 in the 1/2" shank, and another six in the 1/4" shank. The 1/2" inventory includes a set of Jesada straights w/2flutes, two 1/2" pattern bits w/upper and lower bearing, one 3/4" lower bearing pattern bit, one Jesada rabbeting bit with a million bearings of various sizes, and a set of undersized plywood bits. The 1/4" shank bits include two 1/2" two fluted straights, one 1/2" rabbiting bit, and two 1/4" bits. The small shank bits are only used in the laminate trimmer, and the small rabbeting bit has never been used. I also have one small Craftsman HSS veining bit in 1/4" size which I may use one day.
George
>All my brad points and Forstners are also pretty straight, Bill. :<)
>Bill,
I have 8 straight bits from 1/4" to 3/4"
I have 6 upcut spirals from 1/8" to 1/2"
I have 2 pattern bits and 2 flush cuts.
Tom
Don't ask, don't tell
Mark inb'ham
Robert R Clough - Thorncraft
>I think 10 including 2 spiral and 2 pattern type. Plus 4 dado/clean out and 1 for my hinge jig.
Can't tell you...
Hoa Dinh in Alameda
>About half way through counting them (even only in my mind, not actual inventory), I ran out of fingers and toes.
-- Hoa
Dan Manturi
>Bill,
Strsaight bits - Perhaps 10, mostly half inch. Bought cheapies when I first got into woodworking, replaced them with like sized good ones, but the cheap ones still get used a low.
Flush trim - a couple each top and bottom bearing, 1/4" shanks.
Cleanout bits - two or three tops.
Dan Manturi
Rob Sandow
>I have about 20 conventional straight bits. They come in various diameters from 1/4" to 3/4", and most of them came either as add ons to other products (some with the Leigh Jig), or as part of sets of bits. I also have several hinge mortising/bottom flattening bits. I would love to find a source for straight bits longer than 1", as I have none of those and would find them handy for certain operations.
Rob
Re: Rob - check Whiteside
Larry Clinton At Frankfort (Central)., Indiana
>Routerbits.com listed under the marketplace on the left. They have a LOT of bits with cutting lengths over 1" - some to 2 1/2 long. Look under double flute carbide tipped.
>I have several straight bits (over 25) - Most are carbide tipped, although I have an assortment of straight steel bits of odd sizes. I don't have any that I would consider dedicated dado cleanup bits as I usually use a slightly smaller bit than the dado width and set up my fence to make or cleanup the dado making 2 or more passes. Don't have any dedicated "mortising" bits, I have a couple sets of guide bushings and make a jig using a 1/4" bit for hinge mortises. I do have three or four solid carbide spiral bits. I have 2 or 3 different size flush trim & (I think) 3 pattern bits.
Jim Dillon
>Bill,
As near as I can figure (the number keeps changing everytime I count - but that is my age-related problem, not yours 8-)) I have 22 straight bits broken down as follows: 9 straight bits (1/8-3/4 inch); 10 spiral bits (3/16-1/2 inch); 2 flush-trim bits (1/2 inch); and 1 mortising bit (1 inch). While you didn't ask, my most used bit is the 1/4 inch spiral; the least used are two plywood bits. Hope this helps.
Jim
HC Sakman
>Hi Bill,
Spiral bits:
2x1/2" ; 4x1/4" ; 2x1/16" ; 2x3/32" ; 2x3/8" ; 2x5/16" ; 4x1/8"
Spiral w/ bearing:
1/4" & 1/2"
Top bearing flush: 7
Bottom bearing flush: 9
20~25 straight bits of pretty much every size.
Chico...
