A55 Smoothing Plane
OT Any ideas how to cut off a ring from a finger?
Ron in Drums PA
>Long story short.
My mother-in-law needs to have her wedding band cut off, So lucky me, I'm the only one she will allow to do this.
I have a cutting torch, but I would have to sleep on the couch for the rest of my life if I used it. (just kidding)
The ring is pretty thick, I'm afraid that a big pair of cutters may hurt her. I was thinking of using an exacto hobby hacksaw.
Bottom Line:
I really have no clue how to do this, any help would be appreciated.
Thanks
Re: OT Any ideas how to cut off a ring from a finger?
>Good luck. Personally, I'd go to a jeweler. How about a small rotary cutter like a Dremel tool? They are neat tools.
But seriously, they do have small hack saws (aka a jeweler's saw). They cut through silver, gold and copper quite nicely.
Jerry Nicholson
>If you are talking about the really fine X-acto saw (jewelers saw), I think that would work OK and would do less damage to the ring than about anything else. You will probably have to use a diagonal cut. Is there room to slip some kind of shim under the ring in the area of the cut to help protect her from the saw blade?
>Good Morning Ron,
The first calls I'd make is to your family doctor and/or the local ER. They've gone that that procedure before methinks, and should be able to advise the most painless way.
George
Howard
>Ron:
Call your local rescue squad, they may a tool for doing this.
howard
Another possibility...
Jerry Nicholson
>There are small power saws with circular blades that reciprocate rather than rotating. The arc is so tiny that it will just tickle skin rather than cutting it but it will easily cut hard materials. I just know they exist but I have no idea how to find one. Something like this was used in the past to cut off casts - may still be used for all I know.
Jerry
Jeffrey D. Rose
>My father in law had to have his ring removed for work, after being there for 25 years, they all of a sudden relized it was a saftey concern. Ofcourse they shut the plant down less they a year later. Anyways, he went to a jeweler which had a thind that slide between the ring and the finger and then sliced the ring much like a piper cutter. Was cheap, easy, quick, and no pain.
Jeff in Iowa.
Scott Banbury
>Ron,
I used to wear a ring but don't any more.
I quit wearing one after jamming my finger while surfing and subsequently having to cut it off to let the blood circulate.
I used a pair of dykes (wirecutters) and they cut through the silver with no problem.
I imagine gold would be even easier. Much let risky than slipping with a hacksaw or heating it up with a cutoff on a dremel.
Re: Another possibility... *LINK*
Dean Johnson
>(Old ER Nurse here) -- Absolutely go to your local ER, Physician office, or Rescue squad--- They should have the "Ring Cutter" tool which is a device that slides under the ring (protecting the flesh) and then has a small manual cuting wheel which can slice throught the ring--- The ends of the ring are then spread (Using hemostats usually) and the problem solved... If this is done carefully, the ring can then be taken to a jeweler and repaired also...
Here's some other ways that can be tried also:
http://www.ncemi.org/cse/cse1005.htm
Rick L
Re: A special tool is available at ...
Rick L
>jewelery tool suppliers. They coat about $81. Go to a jeweler.
YES--ABSOLUTELY
Thanks
Ron in Drums PA
>Thanks for all the leads everyone, you have been helpful.
Re: OT Any ideas how to cut off a ring from a fing *LINK*
albertabob
>Just snip it with a set of wire side cutters.
No metal loss and no cut skin.
Bob
wire side cutters
Fein Multimaster?
Paul Dwight
>Fein sells metal cutting blades for their reciprocating sander. The arc of the blade is so small that it's not supposed to be able to cut through skin. I believe doctors use a similar tool to cut off casts. I guess the biggest worry would be whether the cutting friction would heat the metal enough to cause discomfort. I've never tried this, I'm only speculating here.
Might be a terrific excuse to get a new tool, though! -- Paul
SawStop
John in MD
>will cut off the ring, and the blade will stop when you're through the ring and before you break the skin.
I'd use an old blade, though, since it will be ruined after the sawstop activates.
Lee Schierer - McKean, PA
>Take her to a jeweler. They have a special tool for doing just that. It does not hurt and it will do minimal damage to the ring. They will also be able to reair and enlarge the ring for a nominal fee. Been there done that, my Mom still wears the ring!
Lee
Nick Tuzzolino
>Your local fire station should have a ring cutter on hand. I've used these often due to swelling, mashed hands, etc. Ask and I'm sure they'll help you out.
By far the best answer!
Ron in Drums PA
>You can't get this type of info on google!
Re: SawStop
Denis Ch�nard, Orl�ans, Ont.
>I think the metal will activate the SawStop mechanism...
DC
They cut mine off at the hospital....
Tim Greif - West of Chicago
>They had to cut my ring off at the hospital when I smashed a couple fingers a number of years ago. They had a little hand powered rotary thingy that slips under the ring and cuts it right in half. No pain, minimal damage.
see saw review on hand tool side
Bill Tindall, E.TN
Darn, you're right
John in MD
>I was just trying to get your MIL to buy you a new tool (seeing as how it's her ring.....)
Re: Darn, you're right
>Uhh, no, not my MIL, maybe I should ask mine, just in case? :-)
DC
John in Calgary
>I've actually done this for my wife and don't recommend it only because I was worried about taking a large snip out of her skin!
The day after our 3rd daughter was born, my wife put on her engagement ring (she hadn't worn it in months as her fingers were quite swollen) - went on quite easy, but then didn't want to come off and actually started to hurt.
I grabbed a pair of nearby end cutters (I was busy wiring up an extra light for the kids in the basement, endcutters are like sidecutters, just with the blades oriented differently). I applied a moderate amount of force and it would not cut through the band, so, being nervous about her finger, I grabbed a chopstick out of the drawer to wedge between the band and her finger to give me some safety margin.
I applied more than moderate force (in fact, I think I actually had to verbally grunt my way through that ring!), and when the cutters finally cut through the ring with a snap, I thought for sure I would have seen blood - with the amount of force I applied, there was no way I could ensure the endcutters stayed still when the cut finally happened.
If there is no discomfort or pain, I'd recommend looking up your local jeweler, medicentre or fire hall to see if they can help out before trying the cut yourself.
John
I used a Dremel tool to do it one time
>Worked just fine
