OT - Fridge problem
Denis Ch�nard, Orl�ans, Ont.
>When we moved in our current house five years ago, the neighbours at the old place had a fridge they had no use for, and offered it to us for free. With a growing family the extra cooling space was welcome, so we installed it in the basement.
This winter, the fridge started to act up. Beyond that drain hose that was clogged, I noticed some frost building at the top back inside the fridge, and the temperature started to rise gradually. A couple months ago I emptied the fridge, let it defrost (even though it's a frost-free unit), and cleaned the drain hose. The fridge was working like new again.
Recently the fridge started acting up again in the same manner. I went tonight to put groceries in it, and the inside of the fridge was barely cool. I can see frost in the inside top back again, and there seems to be little air coming down from the freezer compartment (which is not nearly as cold as it should either).
Is there a simple solution to this problem, or should I swallow the pill and buy another one? This a GE unit, 20 years old.
I'd rather fix this one if there's a cheap solution, that wouldn't cut in the tool budget :-)
TIA,
DC
